ignition timing
  • fat z
  • fat z's Avatar Topic Author
ignition timing
03 Apr 2010 08:08
#358131
Hey KZ'ers, got a question for ya. On my 76 900, I had to replace my dyna-s.I replaced it with another of course,my dilema is,the instructions for static timing the engine(included with the dyna) say to hold the advancer fully advanced and to use the right hand advance mark on the advancer for timing. Other information I have read says to use the f mark on the advancer, and doesn't even mention holding the advancer fully advanced.Which method do i use?
  • Kawickrice
  • Kawickrice's Avatar
Re: ignition timing
03 Apr 2010 08:18
#358134
I use the "F" mark and not turn the advance. Just as the manual says for setting points. 9 out of 10 times if the static timing is dead on the advance will be good when you hook up a strobe. Of course you should always double check it with a strobe. The instructions are confusing with the dyna.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • fat z
Re: ignition timing
03 Apr 2010 08:23
#358138
Thnx, Imma have to reset it. By chance do you know what would happen if I were to leave it advanced.
  • Kawickrice
Re: ignition timing
03 Apr 2010 08:27
#358141
Should be the same. When you set to the "T" with it advanced it should equal setting to "F" without advance. That is of course if the advance is working properly. They should work out the same just different ways of getting there.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Old Man Rock
  • Old Man Rock's Avatar
Re: ignition timing
03 Apr 2010 10:38 - 03 Apr 2010 10:39
#358166
Here you go....
Installation procedure... Covers Static and Dynamic adjustments....
kzrider.com/index.php?option=com_docman&...d&gid=449&Itemid=108
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 03 Apr 2010 10:39 by Old Man Rock.
