kz650 battery removal
- kzbobber2
- 1980 kz650
28 Mar 2010 16:31
i have an 80 kz650,i dig kickin the bike over,do i absolutly need a battery
- MFolks
Re: kz650 battery removal
28 Mar 2010 17:57
The battery acts like a surge tank, that is it absorbs voltage surges and stabilizes the output of the regulator/rectifier after receiving the alternators A.C. output.
Some riders have replaced the battery with a large capacitor(I'm not sure what voltage of MFD they used).(MFD = Microfarads,how electrical capacitors are rated). In Canada/England, maybe Europe they call them condensors.
- MFolks
28 Mar 2010 18:01
Another thought: with the battery out of the circuit, any quick run through the gears will quickly burn out any lights(headlight,tailight,turn signals, and instrument lights) due to uncontrolled voltage surges and possibly damage the ignition system too.
- loudhvx
28 Mar 2010 22:00
The capacitor acts like the battery, but is much smaller and much lighter. Only bikes with permanent magnet alternators can do this mod. The capacitor is needed to make the regulator able to regulate properly, and store a bit of energy for when it is needed in pulses for the ignition.
6000 microfarad (usually written as MFD or uF) to 12000 microfarad, 50 volt, electrolytic capacitor should work.
The regulator is still in the circuit so it should not go over about 14.5 volt same as stock.
If the reg/rec on the bike has a brown sense wire, that sense wire should be tied permanently to the positive side of the cap. That's really the only change needed to replace a battery with a capacitor. Your bike, I think, has a 4-wire reg/rec (Red, black, 2 yellow) so this won't be an issue for you.
I've been running one for about 2 years, with no real problems, but before doing this mod, make sure the bike is tuned well enough to reliably start in one kick or so.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- kzbobber2
- 1980 kz650
- kzbobber2
- 1980 kz650
29 Mar 2010 12:55
do i disconnect or do i tie it in and to what color,and whats the best way to ground this, i know a bit bout these electrolytic caps.cause i repair antique tube radios/guitar amps
- loudhvx
29 Mar 2010 20:38 - 29 Mar 2010 20:40
The capacitor has a positive and negative terminal just like a battery. You just hook up the cap in place of the battery. Obviously the cables for the battery will be too big and heavy for the cap, so you will probably have to replace the cables with smaller wires etc. But you may want to do that anyway for cosmetic reasons. Also if it proves reliable, you may eventually want to rewire the bike to have the bare minimum wires.
You want to make sure the cap is mounted firmly and protected from water and heat. But make sure you don't crush it. The clamp you use should have some rubber in it to hold without a lot of pressure. The caps are easy to crush.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 29 Mar 2010 20:40 by loudhvx.
- kzbobber2
- 1980 kz650
- rkan
31 Mar 2010 23:11
Is your starter button part of your throttle? Cause on my '78 kz650 it is. would you replace the throttle or just keep it?
1978 KZ650B
- kzbobber2
- 1980 kz650
