Ignition upgrade 77 kz 1000
  • tburn
  • tburn's Avatar Topic Author
28 Mar 2010 10:45
#356728
Was wondering if someone could shoot me in the right direction. 1977 KZ 1000 Bored out to a 1175, bigger carbs w/ K&N filters, Accel Super coils with the 8.8 wires.Runs pretty good but still has the old points set up. It does have a Dyna rev limiter on it but not sure if its hooked up right. Never wound it up that high yet. But I would like to upgrade the ignition to electronic. Whats my best bet for just everyday cruising and maybe a little twist here and there. Also are the Accel coils ok to use with what ever is suggested. Thanks for help.
  • MFolks
  • MFolks's Avatar
Re: Ignition upgrade 77 kz 1000
28 Mar 2010 12:41
#356737
www.z1enterprises.com can get you into a Dyna "S" that replaces the stock ignition points. For a good upgrade, look at getting a set of the Green 3 ohm coils along with new sparkplug wires.
Some riders like the Grey 2.5 ohm coils for a hotter spark.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
28 Mar 2010 13:22
#356743
1977 KZ1000 A-1
  • porchev914
  • porchev914's Avatar
28 Mar 2010 13:28
#356745
Wouldn't the Accel coils work fine with a Dyna S?
FRANKEN Z!
  • keith1
  • keith1's Avatar
28 Mar 2010 13:31
#356746
they do on my bike.....
  • loudhvx
  • loudhvx's Avatar
28 Mar 2010 15:14
#356763
The Accel 3 ohm coils are perfect for the Dyna S.
The dyna S has a warning not to use coils that are less than 3 ohms. Less than 3 ohms stresses out the Dyna S and would unnecessarily heat up the coils.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
28 Mar 2010 15:24 - 28 Mar 2010 15:25
#356767
the next step up from ths S is the Dyna 2000. it also replaces the manual spring advancer with an electronic computer type curve.it has 2 built in advance curves. 1 for stock, and 1 for bikes like yours with modified motors.
it also has a built in rev limiter, and can run on the 3, or 2.2 ohm coils.B)
Are u shure u have 1175cc and not 1075, or 1135cc? i havent heard of a 1175?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 28 Mar 2010 15:25 by mark1122.
  • dejavoodo41
  • dejavoodo41's Avatar
28 Mar 2010 17:43
#356800
I run the Dyna S with the Green Dyna coils and love it
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
28 Mar 2010 17:47
#356801
+1 Good tuff ;)
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • mtkawboy
  • mtkawboy's Avatar
29 Mar 2010 15:16 - 29 Mar 2010 15:16
#356997
Same set of green Dyna coils, wires & Dyna S on my 1105 76 going on 30 years trouble free. I put an 80 factory electronic setup on another 78 KZ1000 I have too with no problems
Last edit: 29 Mar 2010 15:16 by mtkawboy.
  • kenskz1000
  • kenskz1000's Avatar
29 Mar 2010 16:09
#357024
your coils are fine, get the dyna s
