83 kz650 csr
- scerbz
83 kz650 csr
27 Mar 2010 22:30
i have had this bike only a short bit, yet have had to hook the battery up to a charger several times... some days i take it out, and it randomly kills, and wont start again... the battery is new. it takes a few good days between charge. i have no idea if its my start button, a wire, or the charging system. help?
- rstnick
Re: 83 kz650 csr
28 Mar 2010 04:40 - 28 Mar 2010 04:42
Welcome.
Are the fluid levels up to the upper line on the sdie of the battery?
If so, then some tests of the charging system are in order.
Here are some posts that may have your answer:
forums.kz650.info/index.php?action=search2
That link just takes you to a search box.
Type in stator testing for some similar problems.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 28 Mar 2010 04:42 by rstnick.
- JMKZHI
Re: 83 kz650 csr
28 Mar 2010 07:59
Howdy. Get a manual for your bike. A factory manual for an 83 Kz650 might be kinda rare. An 81-82 650 manual may be fine.
What type of charger did you use?
And was the battery properly charged etc before putting it into service?
- MFolks
Re: 83 kz650 csr
28 Mar 2010 12:50
The website
www.electrosport.com
has a troubleshhoting page to help diagnose charging problems.Sounds to me either your alternators stator(the wire windings) are damaged or the regulator/rectifier is not working properly.
If after troubleshooting that the regulator/rectifier is determined to be bad, try this website for replacement:
www.oregonmotorcycleparts.com/Products.html
A list of rebuilders/new manufacturers of stators/regulators:
www.rmstator.com
www.customrewind.com
www.regulatorrectifier.com
www.ricksmotorsportselectrics.com
www.rmstator.com
- scerbz
Re: 83 kz650 csr
28 Mar 2010 15:15
well, the battery is fine. ive been lookin for a manual. found a few, but got to order it. so was just curious for some ideas. and the charging system seems to be the most likely, because unless its hardly turning over(low batt) i usually can start it no problem. but sometimes, if i leave it alone then go back to it a bit later i can get it to turn over more than once or twice like when the battery is drained.
- H1Vindicator
Last edit: 20 Feb 2013 19:14 by H1Vindicator.
