Points Adjuster Screws (1978KZ 650)
  • sft1662
  • sft1662's Avatar Topic Author
21 Mar 2010 15:02
#355244
KZ 650
Does anyone know where to find the little gold screws that are used to tighten down the points after adjusting the gaps? I went to adjust the point gaps yesterday and the head was completely stripped out of both of them on the right set of points :blink: ... Had to use tiny needle nose vise grips to finally loosen it up and adjust them (they looked new, but the gaps were about twice as wide as suggested).
Anyway, does anyone know where I could find these screws, checked Z1, no luck. I found the whole ignition set on ebay for about 50$, but I'm not going to pay that just for a couple of screws. Of any tips for how to deal with this? The visegrips work for now, but I know that I'm not always going to have them handy when I need to adjust the gaps, and the screw head will get rapidly chewed down after a couple more adjustments.
I hope to go with an electronic ignition someday, but thats probably not in the cards anytime soon.
Thanks in advance!
1978 KZ650 B2A
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Points Adjuster Screws (1978KZ 650)
21 Mar 2010 17:24
#355282
The kawasaki parts diagram shows them as "SCREW PAN HEAD 4X8".
4 x 8 mm. You might be able to find some at your local hardware or Home Depot.
This post details how to find and use the parts diagrams:
forums.kz650.info/index.php?topic=812.0
Some members here or on the 650 forum (linked above) may have some spares if your lucky.
Welcome as well.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • timebomb33
  • timebomb33's Avatar
21 Mar 2010 17:27
#355284
welcome to you as well i would like to help but i threw all my points plates away years ago. i always use dyna ignitions myself
I THINK MY POWERBAND BROKE
  • sft1662
21 Mar 2010 17:57
#355299
Hey thanks! I did not know that there were parts diagrams available from Kawasaki, very cool. Hopefully I can find a replacement at the hardware store, in the meantime I'll be using pliers.
1978 KZ650 B2A
