Ignition coils and plug wires
- kzcody
29 Mar 2006 21:24
does anyone know if the plug wires on the ignition coil from a 80' 440 ltd are seperate from the I. coil? I need to replace the wires but I didn't want to just pull them out and find out later that they weren't built to do that. Thanks,
cody
cody
- JR
Re: Ignition coils and plug wires
30 Mar 2006 03:25
Lets see if I can post a pic. Not sure about your bike and coils but if the wire or wires have a collar where the wire enters the coil then you can unscrew the collar and remove the wire, If no collar then perhaps you can cut the existing wire and splice a new one ?
- kzcody
30 Mar 2006 16:12
Ok thanks, that helps alot, looks like I'll have to cut and splice. thanks again
- JR
30 Mar 2006 17:37
I've never done it but have heard that there are little thingies available to help join the new wires to the old. It might be a good idea to search the archives or check at a local auto parts store.
Good luck
Woodstock ON Canada
1980 kz750E1, 4->1, K&N pods
Good luck
Woodstock ON Canada
- Sandy
- Fly High,Tony
30 Mar 2006 21:07
These ones,I got from NGK,and they DO work great!
You just cut off the wire at the coil(leaving a couple inches from the coil),and install these.
There's plastic tapers and rubber compression fittings inside,so they're waterproof,and it also makes for a snug fit.
1977 KZ1000 A-1
- inline4
30 Mar 2006 21:48
Sandy, you are The Man! You've evolved into quite a wrencher; especially for a Canadian!:laugh:
I hope all is well with you.
Jim
Jim
- Sandy
- Fly High,Tony
30 Mar 2006 22:19
inline4 wrote:
LOL...Why THANK YA,Jim...thank Ya very much!
"Especially for a Canadian"...HEY...don't make Me throw a snowball atcha!:whistle:
Yup...I definately HAVE learned a lot about My bike over the years...and thanks to Guys like You,Jim(and a lot of Others)...there's not a whole lot that I HAVEN'T learned about,and done to this ol Kaw.
Hell...it HAS to be worth at LEAST...$50k by NOW...huh?LOL
Jim
1977 KZ1000 A-1
