point specs
  • roxygozoom
  • roxygozoom's Avatar Topic Author
point specs
14 Mar 2010 08:02
#353268
i'm trying to find the point specs for a '78 KZ650. anyone able to help me out?
'78 KZ650
  • sabell
  • sabell's Avatar
Re: point specs
14 Mar 2010 08:45
#353281
'78 KZ1000A2
'79 650SR
  • roxygozoom
Re: point specs
14 Mar 2010 09:22
#353286
thanks. got my points, what i need to know know is how to time it and what the gaps should be at
'78 KZ650
  • sabell
  • sabell's Avatar
Re: point specs
14 Mar 2010 09:50 - 14 Mar 2010 09:55
#353290
Here's a link to an old thread most 650 models/years are about the same, there are other threads if you do a search.
kzrider.com/index.php?option=com_kunena&...d=2&id=169496#169544
Link to a manual download.
forums.kz650.info/index.php?topic=2540.0
'78 KZ1000A2
'79 650SR
Last edit: 14 Mar 2010 09:55 by sabell.
  • Kawickrice
  • Kawickrice's Avatar
Re: point specs
14 Mar 2010 10:05
#353295
After you get the points and condensors mounted you should gap them, both sides. After they are gapped you need to get them to fire at the right time. I use a pointed test light for this, I ground the light with the alligater clip then with the key "ON" rotate the 17mm nut with the test light on the points, the light should come on when the marks behind the plate line up. You want it to fire on the F mark and not the T mark.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • roxygozoom
Re: point specs
14 Mar 2010 10:09
#353298
thanks ya'll. i'll give that all a try today
'78 KZ650
