Coils
- triggerman
Coils
13 Mar 2010 20:08
I have just purchased a 81 kz1000csr carbs were nasty dirty, cleaned them out maybe not good enough cuz im still not getting fuel into the cylinders but i poured some gas into each cylinder tryied startig it and it kinda sounds like is out of time, but im thinking that maybe the sparkplug wires are not right i got a repair manual but i cant find where it says wut wire goes to wut plug... can anybody help me?
- timebomb33
Re: Coils
13 Mar 2010 20:43
if you have a repair manual then go to the wiring diagram and chase the connections from the ignition plate to your coils then you can figure it out from there.
I THINK MY POWERBAND BROKE
- timebomb33
Re: Coils
13 Mar 2010 20:45
if you have a repair manual then go to the wiring diagram and chase the connections from the ignition plate to your coils then you can figure it out from there.the coil on the right will be 2&3 the coil on the left will be1&4. no 1 cylinder is the first one on the left.
- MFolks
Re: Coils
13 Mar 2010 21:40
As you sit on the seat, the sparkplugs are numbered left to right, 1-2-3-4, The LEFT ignition coil sparkplug wire go to #1 and #4. The RIGHT ignition coil sparkplug wires go to #2 and #3.
The ignition coil have dual ports wired together, so it really makes no difference on which port goes to what plug, so it's not hard to do.
As for the ignition point wiring, consult a shop manual with a wiring diagram.
- triggerman
- triggerman
Re: Coils
14 Mar 2010 07:03
one more question guys if you dont mind.... the manual that i have when i go look at the wiring diagrams i cant find my bike model mine is a kz1000csr and in here i have kz1000 J1,Z1000J1, KZ1000K1,KZ1000M1 are all these models kinda similiar?
- otakar
Re: Coils
14 Mar 2010 07:11 - 14 Mar 2010 07:13
The CSR is a KZ1000M(1-3)There is quite a big difference between the other models, when it comes to the electrical diagrams.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 14 Mar 2010 07:13 by otakar.
- otakar
Re: Coils
14 Mar 2010 07:18 - 14 Mar 2010 07:27
If you did not remove the wires from the coils, and you did not remove the coils from the bike, it would be quite difficult to put the plug caps to the wrong plug. There is a very large difference in wire length. If by some chance you mixed up 1 with 4 or 2 with 3 which MIGHT be possible, it would not make a difference because those fire at the same time anyway. Now, if you removed the coils from the bike than you might have a problem.
The bike in this picture started out life as a 1981 CSR (M) you can follow the build in this link. The wiring harness in this bike is the same as in yours, plus the changes that I made for the front instrument section. In this picture the engine and ignition were still stock CSR components with the exception of the "Dyna" 2.2 Ohm (gray) coils. Which would not be a bad idea for you to get. They are not that offal bad in price new, but I bought mine used on eBay for about $45 for the two.
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=169462
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 14 Mar 2010 07:27 by otakar.
- otakar
Re: Coils
14 Mar 2010 07:31
No eBay APP ID and/or Cert ID defined in Kunena configurationHere is a set of brand new Dyna coils for that bike at a fantastic price.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- triggerman
Re: Coils
14 Mar 2010 07:54
thanx for the tips...as far as me taking the coils off is a no... i just got the bike yesterday and at firs i was only getting spark from one coil (2 sparkplugs) so i traced the wires that go to the igniter box and just move them around and the i got spark on all 4 but i dont know how to tell if is a weak spark...
- otakar
Re: Coils
14 Mar 2010 08:16
Measure the voltage going into the coils while the bike is running. If you have anything over 12V than you have a stock spark. The only time I have seen coils be bad is if they're cracked. If the voltage going to the coils is below 12V than clean all electrical connectors in the ignition system.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
