- Thank you received: 3
LED 1157 bulbs from eBay?
- 9am53
- homebrew, and some bbq
cgi.ebay.com/5x-1Watt-Red-Super-bright-7...?hash=item255939eb52
www.customfighters.com/forums/showthread.php?t=27905
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- JakeB
I started to make my own led signals like otakar, I only actually got one done so far, but I found that the white leds tend to pass right through the diffuser/filter without picking up much color. At least they did on the smoked amber lenses that I had with cheap white leds. It may a be different story with the red lenses, but I still think the red leds would look much better!
Another issue I have is that the leds I have are very directional, and it's difficult to get them to be bright enough for people to see. For that reason I'm going to put the incandescent bulbs back in until I have more time to tinker with the leds. Some of the 1157 replacements look like they would not have that problem with the leds pointing in every direction though.
Good luck, and let us know what works!
1978 Z1-R
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- 9am53
'84 GPz900r
'71 CB350
- Thank you received: 2098
- 9am53
I believe these are the ones you were talking about bobofet, I just can't figure out how I would hook them up! I wonder if the back has pins to solder...hmm, 5 of these for brakes and 5 little LEDS for running light...
this is handy too:
led.linear1.org/led.wiz
'84 GPz900r
'71 CB350
- JakeB
I got mine from dealextreme, when you buy them in bulk they really come down in price. I think I got my white ones for around 7 or 8 cents a piece, but I got 200 of them. The colored ones are a little more expensive but still not bad. The only issue is that they have a small viewing angle like 30° I think, maybe even less.
By the way, if you are trying to make your own to save some money, don't! :laugh:
I got the four turn signals to modify for about $40, then I spent another $30 on leds, and probably another $15-20 in padboard, resistors, and other things.
So with right around $90 in stuff to do this I could have gotten some really nice led units ready to go. And I have even thought about doing that now, but I have everything I need and just have to put the stuff together. This has definitely turned into more of a pride issue than anything. :laugh:
1978 Z1-R
- 9am53
JakeB wrote:
You can get leds with up to 170° viewing angle, but at over $4 each they aren't giving them away. You can find a good assortment at digikey and mouser.
'84 GPz900r
'71 CB350
- bountyhunter
- Thank you received: 337
www.superbrightleds.com/cgi-bin/store/in...ake-turn.html#Table1
- 9am53
'84 GPz900r
'71 CB350
- bountyhunter
Problem is if you get enough LED power to give you sufficient brightness, you need a decent heatsink. The ones above have the aluminum heatsink built in. If you are going to use LEDs for brakelight or rear turn signals, you really need them bright for safety. Most of the junk I have seen from ebay is not bright enough. In fact, superbrightleds.com has a warning on it's site that most LEDs are too dim for that usage.those look bright enough, BUT for 40 bones I think I will pass and make my own.
The one posted in this thread which is labeled "3W"is rated at about 0.7A @ 3V which is over 2W of power dissipation. It might be bright enough, but that's a lot of power to get out. When you look at the small size, that heat has to be conducted out to the PC board traces that the small sub board mounts to. 2W is actually a lot for such a small device, and they die if the temp goes above about 160C. The life span is proportional to the operating temp logrithmically and drops by 1/2 for approximately each 10C rise of temp. Getting the heat out of the LEDs is a big problem and it's the reason cars don't have LED headlights.... (yet).
- 9am53
'84 GPz900r
'71 CB350
