kz650 turn signals
  • mjwriz
  • mjwriz's Avatar Topic Author
kz650 turn signals
29 Mar 2006 11:09
#35204
for some reason my my turn signals turn on, but they don't blink. any suggestions?
  • mariozappa
  • mariozappa's Avatar
Re: kz650 turn signals
29 Mar 2006 11:15
#35205
you can check your turn signal relay under your sidecover and see if that's the problem.
You can get a new at an autoparts store for under $10.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
29 Mar 2006 11:16
#35206
If all 4 bulbs come on, 2 at a time, then it's most likely the turn signal relay. Try cleaning the wire connections to the relay. If a bulb is burnt out, the other wont flash.
Could also be the strength of your battery, or the engine may need to be running to generate more power.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
