electronic ignition timing
  • wes_scooter
  • wes_scooter's Avatar Topic Author
08 Mar 2010 14:21
#352003
what would the timing be while at idle and at full advance. bike is a 76 900a2 stock. besides the ignition.
it advances at like 3k i beleave? i want to check with timing light. my bike has a vintage aftermarket system on it. one with a optical type of sensing system.
76' kz900
70' yamaha R5
2006 wr450f
Re: electronic ignition timing
08 Mar 2010 14:32 - 08 Mar 2010 14:37
#352006
Use strobe type timing light to align F mark for 1/4 with case mark at idle rpm. Repeat for 2/3.
Watch advancer quickly move back and forth as throttle is blipped.
Good Fortune! :)
Last edit: 08 Mar 2010 14:37 by Patton.
08 Mar 2010 14:42
#352010
Advancer marks may look like this one.
Ignore the T mark for purposes of ignition timing.
Good Fortune! :)
08 Mar 2010 14:53
#352014
Or it might look like this one.
  • wes_scooter
08 Mar 2010 15:25
#352018
so i take it that i should set my timing light at 0' and at idle make sure the f mark and the line in the case match up.
76' kz900
70' yamaha R5
2006 wr450f
08 Mar 2010 15:31
#352020
Yes, presuming the timing light is adjusted to flash when the plug fires.
Good Fortune! :)
  • MFolks
  • MFolks's Avatar
08 Mar 2010 15:41
#352023
The mechanical advancer should be able to be moved by hand and then return to it's original setting, if not, it may need cleaning and lubrication on the pivot joints(places where the springs attach, the weights pivots, and the main shaft where the securing bolt goes).
Take pictures/notes as to how it's assembled as it can be 180 out if put back together wrong.
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
08 Mar 2010 17:08
#352055
So for my own benefit, what happens if the timing is a little off? How can you adjust it to be right?
  • Old Man Rock
  • Old Man Rock's Avatar
09 Mar 2010 04:40
#352135
One of two ways...
In the DYNA installation procedure, after the plate is installed and wired correctly, you first do a static alignment with a (+12Vdc light to ground) light probe.
Then you adjust the individual pickups that are on the plate by loosening the screws for each pickup.
In Dynamic, you loosen the plate screws themselves and rotate the plate for timing light alignments and test for 1/4 & 2/3 timing.
Here's a write I up I put together when doing mine... Located in the KZR file base... ;)
kzrider.com/index.php?option=com_docman&...d&gid=449&Itemid=108
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • 9am53
  • 9am53's Avatar
09 Mar 2010 17:17 - 09 Mar 2010 17:25
#352288
My bike came with electronic ignition and does not have the slots to make adjustments. I will ream out the holes to make slots if I need it then I guess, thanks! In your instructions you say at the end to rev up to 2500 rpm and use a strobe light using the "T" mark, I thought "T" was just for finding top dead center
Last edit: 09 Mar 2010 17:25 by 9am53.
  • Old Man Rock
09 Mar 2010 17:22
#352289
"No slots to make adjustments."...
Safe to assume that the OEM procedure would be to align the pickups them,selves then... Your manual should be able to provide some insight on how to accomplish....
Is your timing off per specifications then?
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
09 Mar 2010 17:27
#352291
If the oem ignition timing isn't adjustable, do the timing marks fail to align when viewed under a strobe type timing light? :unsure:
Good Fortune! :)
