Ignition coils question
- clutch85
07 Mar 2010 15:05
hello i have a 1980 kz440. I am getting really weak spark and it will not start. i checked all the wires with multimeter and conncections were all good. It is getting gas. The points are sparking also. It just will not start for nothing. It ran great about too weeks ago but it had really good spark then. I checked the coils and they are within specs I am stumped! It has to be the coils so what i wanted to know was if i could just buy 12v automotive coils like my buddy did for his honda 350. He did mention that he had two sets of points though so i was wondering if anyone could help Thanks!!!!
- MFolks
Re: Ignition coils question
07 Mar 2010 15:43
Does your bike have electronic ignition or the standard points? To see what you've got,remove the cover over the point area.
Have you looked at this website too?
www.armbell.com/forum/viewforum.php?f=17...cbefe27&mforum=kz400
- clutch85
- MFolks
07 Mar 2010 21:10
Have you checked the primary and secondary windings with a multimeter? The primary connections are where the smaller wires go. To check the secondary windings, the sparkplug cables/leads will have to be removed to access the spike inside the ignition coil.
I'd say the primary side will read 2.8-3.0 OHMS, the secondary side, somewhere between 10.4 and 15.6 K (Thousand) OHMS.
Also see if the sparkplug caps are any good.They can fail reducing the spark energies.
- loudhvx
07 Mar 2010 23:12
Car coils would be a waste.The dwell is too long for them on the KZ so they will just be wasting energy as heat. In order to not melt the points, you would have to put in some big ballast resistors which would also waste energy as heat.
Just get a 3 to 4 ohm dual-plug coil. It would be the easiest and most efficient solution. 3-ohm would give hotter spark, but will shorten the life of the points a bit. 4-ohm would be like stock.
Are you sure it's not a low-voltage problem at the coil?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- clutch85
07 Mar 2010 23:19
would these work?
www.debrix.com/ProductDetails.asp?ProductCode=32-0126-VT
im not sure what you mean with the low voltage..
- Old Man Rock
08 Mar 2010 01:07 - 08 Mar 2010 01:10
@ Z1...
www.z1enterprises.com/catalog.aspx?pid=KZ440-B1-1980-IG0
Unknown which exact model A/B or what the resistance values are in your bike... but here's an image of what is available @ ~ $70....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 08 Mar 2010 01:10 by Old Man Rock.
- MFolks
08 Mar 2010 10:30
Fully charge the battery and then use a multimeter, checking the input(primary) side of the ignition coil.
It should be the same as battery voltage. If lower(like 8 volts or so)you may have a resistance problem (dirty electrical contacts or connectors).
- loudhvx
09 Mar 2010 10:07 - 09 Mar 2010 10:10
clutch85 wrote:
That coil would probably work, but I'd rather see a 4-ohm coil to go with the KZ's 180-degree dwell. Plus that coil looks kinda cheap.
One fo the coils listed by OldManRock would probably be better. If you will stick with points, then try the 5-ohm Dyna. If you think you will go to electronic ignition at some point, then go with the 3-ohm. Dyna or Accel coils would be at the top of the list for reliability. Z1 also sells 4-ohm Emgo coils which are just like the stock coils, but some have concerns about the quality on those.
Mfolks describes how to check for the low voltage at the coil.
would these work? www.debrix.com/ProductDetails.asp?ProductCode=32-0126-VT im not sure what you mean with the low voltage..
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 09 Mar 2010 10:10 by loudhvx.
- bountyhunter
09 Mar 2010 11:02
clutch85 wrote:
Z1 Enterprises sells the OEM replacement four Ohm coils for $36. I am running one on my 750.hello i have a 1980 kz440. I am getting really weak spark and it will not start. i checked all the wires with multimeter and conncections were all good. It is getting gas. The points are sparking also. It just will not start for nothing. It ran great about too weeks ago but it had really good spark then. I checked the coils and they are within specs I am stumped! It has to be the coils so what i wanted to know was if i could just buy 12v automotive coils like my buddy did for his honda 350. He did mention that he had two sets of points though so i was wondering if anyone could help Thanks!!!!
- clutch85
09 Mar 2010 16:32
thanks for all the replies! helps out a ton, think i will go will the oem z1 coils for 36 bucks since im on a real tight budget
- nads.com
