What size Plug gap do you run ?
  • loudhvx
  • loudhvx's Avatar
Re: What size Plug gap do you run ?
10 May 2010 10:08 - 10 May 2010 10:18
#367023
The only problem using a wider gap at the plug is that it really stresses out the coil insulation. I know it doesn't seem like a few thousandths should matter, but the voltage spike on the primary can go from 300 or 400 volts to 600 or 1000 volts. This means the igniter's output driver has to deal with a much larger voltage to insulate against. This means the coil's insulation also has to deal with that. The secondary side will be around a hundred times higher than the primary side. Eventually, the spark energy will try to find an easier path to take.
10 years ago when I started building igniters (not the HEI ones), I used old coils for testing. When I bench tested them in open air using a 3/8" gap (in open air the pressure is much lower so you use a much wider gap to simulate the cylinder pressure), the coils lasted indefinitely. If I increased the gap to about 3/4", they would last a couple hours then you'd hear a little ticking noise in the coil and the spark would get real weak, then eventually stop. After that I could barely get a 1/4" gap out of them. Granted, these were 30 year old coils, but they were in decent condition.
The compression ratio makes a difference. The higher the cylinder pressure is before ignition, the higher the voltage stress is on the ignition. On one of my gpz's (which has higher than 10:1, maybe 11:1) I can't go much higher than about .035" on the gap before the wires start or coils start to bleed off.
I'm not saying to not run a larger gap, but if it runs fine or basically the same with a normal gap, then I'd say use the normal gap to get more life out of the coils and igniter. This could just mean the coils last 20 years instead of 40 years, so maybe it doesn't matter.
Last edit: 10 May 2010 10:18 by loudhvx.
  • otakar
  • otakar's Avatar Topic Author
10 May 2010 10:14
#367024
I talked to Dyna about that and they told me directly that it is no problem. I was told that in some applications people run as much as .100"-.120" gap on the plugs with those coils. I was worried about that also, so I called them to ask just for that reason.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • loudhvx
  • loudhvx's Avatar
10 May 2010 10:25
#367025
Well, as I said, maybe it's just a longevity issue, or maybe newer coils are just better, but I doubt they did much stress testing on old igniters, or maybe they did, but I would assume they tested with their own ignitions. I guess if the old Kaw igniter pops, the HEI's are cheap enough.
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
10 May 2010 11:17
#367032
Cool! Otto is setting me up with the good stuff.
I've had these 3ohm Dyna coils sitting on my shelf for over a year. Now I can use 'em!B)
Gotta rewrite some ZZ Top now.
New coils, new wires, when I twist back I'm gonna fly-like-fire...:laugh:
  • bountyhunter
  • bountyhunter's Avatar
10 May 2010 11:54 - 10 May 2010 11:55
#367042
But they are in the business of selling coils.:laugh:
The Kettering ignition is a flyback design. I used to wind switching transformers and there is always a tradeoff. More (and better) high voltage insulation between winding layers costs money and increases size. But, transformers do fail over time. Heat is a major stressor, but the high voltage creates the E field that works on the insulating material and eventually punches through. Dyna coils may have a good operating life at wide plug gaps, but it definitely increases stress for the reasons already listed (higher voltage induced).
I had forgotten about the induced back EMF on the primary working over the solid state switch, but that's real too.
Last edit: 10 May 2010 11:55 by bountyhunter.
  • loudhvx
  • loudhvx's Avatar
10 May 2010 21:15
#367147
Yeah, I knew it was there, but still managed to smoke a oscope probe somehow. It was up to about 600v before it went. Not sure what happened. Probably the voltage divider shorted.
  • otakar
11 May 2010 05:50
#367177
Well he is ONLY going to run .045" gap which is a standard non radical gap. So, there's no worries. I'll experiment with the .060" gap on my bike.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Hollywoodmx
  • Hollywoodmx's Avatar
05 May 2012 15:10 - 05 May 2012 15:11
#519989
On my B2 GPz 1100 I installed my 2.2 dyna coils, 8mm taylor wires. I broke one of my iridium tips, better that happened in my gapper vs the engine so I bought BR8ES (IIRC) instead. Gapped to '0.525'.
Bike revs quicker and cleaner the top end is noticeably more aggressive. Since I am at 4200ft I'm not sure if that plays a role in whats best for my gapping.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 05 May 2012 15:11 by Hollywoodmx.
  • otakar
05 May 2012 15:41 - 05 May 2012 15:42
#519995
I have run as much as .80 with no problems and had good response. That is a whole 2mm gap. The problem comes because the coils start to run much hotter and you get feedback into the ignition. I found that .60 is the best of both worlds. I do not run Iridioum or any of the new metal plugs because they do nothing for our bikes. The ACCEL/ND U plugs are still the best and last the longest.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 05 May 2012 15:42 by otakar.
05 May 2012 16:09
#520002
+1 on the ND U plugs. Ed
05 May 2012 18:41 - 05 May 2012 18:42
#520027
Hollywoodmx wrote: ...BR8ES....
The "R" means its a resistor type spark plug, with resistance being built into the plug itself.
Where resistance is desired in the secondary loop, it may be introduced in either of three places:
• An "R" spark plug;
• A resistor incorporated into the cap that clips onto the spark plug;
• Suppression type spark plug wires.
Should NOT combine these, as a single form of resistance is sufficient.
And using more than one introduces too much resistance.
It would be a royal screw-up to use R plugs with suppression wires and resistor caps.
On older vehicles where electrical interference is not an issue, no resistance is needed, and B8ES (non-R) plugs with solid copper core wires and non-resistor caps may be fitted.
On newer vehicles with electronic advance ignitions or other sensitive electronic equipment, resistance may be added to the secondary loop by using one, and only one, of the mentioned methods.
Have successfully long enjoyed using on Z1 and KZ900: NGKB8ES (non-R), and Dyna solid copper core plug wires with built in non-resistor caps. But the ignition overpowers most local audio sources.
Good Fortune! :)
Last edit: 05 May 2012 18:42 by Patton.
  • Hollywoodmx
07 May 2012 00:48
#520412
Sorry I did buy the B8ES's, not the R's although the iridiums were r's.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
