What size Plug gap do you run ?
  • otakar
  • otakar's Avatar Topic Author
Re: What size Plug gap do you run ?
21 Mar 2010 08:53 - 21 Mar 2010 08:54
#355149
Yes the gap can be a C##t hare larger but not a red one that is too thin a blond one is a bit thicker but a non domestic black one is the thickest and I would go with that. :laugh:
.045 -.060 is very good. I think for most people .045-.050 is the way. But different plugs will react differently. This is the advice for the ND/ACCEL or Beru/Nology plugs
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 21 Mar 2010 08:54 by otakar.
  • otakar
10 May 2010 07:26
#366990
This one is for "riverroad" he was looking for this post.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
10 May 2010 07:55
#366992
Thanks otakar. But I'm still running my stock coils. They still work. I do have soem of the green coils I bought cheap from some dude, but I haven't gotten around to changing them.
Anyway, I have a trip coming up and was thinking about upgrading to better plugs, but for this trip, since I have plenty of other crap to do, I'm gonna wait til I get back to deal with the coils.
Guess for now I'll just stick in another set of NGK's. About a buck fidy at the Farm and Home.
Kind of annoyed myself yesterday. For the last week I've been cleaning up the engine with the power washer and what not. Had the tank off and forgot to plug the fuel lines. So when number one cylinder went dead yesterday while test riding myu new Kerker, I thought sure it was a carb problem. Dropped number one float bowl to see what it could be. Nothin wrong there. So finally I switched number one and number four plugs. Yep, dead plug.
DAH!!!
  • otakar
10 May 2010 08:06 - 10 May 2010 08:08
#366994
It will take you less than 1/2 hour to change the coils and remove the ballast resistor. You are wasting a lot of energy with that resistor in the circuit. You can run those plugs just like you would run the NGK B8ES but you will run the stock gap on them with the stock coils. Once you change the coils than you can open the gap to what ever you desire or leave it stock. Those plugs are a direct replacement for the NGKs
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 10 May 2010 08:08 by otakar.
  • riverroad
  • 1980 1000LTD B4
10 May 2010 08:43
#367000
OK, what plug wires and boots do you recommend?
Solid core I'm sure but which ones?
And do I splice the ballast resistor wires together?
  • otakar
10 May 2010 09:03 - 10 May 2010 09:21
#367005
Yes once you unplug the resistor you will plug the two wires together because the resistor is in series with the coils. I make my own plug wires but you can buy virtually anything from Z1E in solid core.
www.z1enterprises.com/detail.aspx?ID=209
OR
www.z1enterprises.com/detail.aspx?ID=208
Coils
www.z1enterprises.com/detail.aspx?ID=210
Or if you want to come over we can make a set of wires. I have blue solid core wire. I have the crimpers for the end caps
Call Me anytime
(burr ridge) Rt 83 & 91st St. 1/2 Mi So. of(I-55)
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 10 May 2010 09:21 by otakar.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
10 May 2010 09:07
#367006
I can still get NipponDenso plugs... :huh:
or am I missing something :P
Here is there "Find Your Plug" web reference chart. Some plugs have to be ordered from Japan.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • T_Dub
  • T_Dub's Avatar
10 May 2010 09:11
#367007
I have the suppression wires on mine, I found them easier to get to work properly.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • otakar
10 May 2010 09:13 - 10 May 2010 09:20
#367008
Yes you can. Today the Iridium plugs are the rage for everyone but I don't Like them not even the Denso. I bought a massive quantity of the W24ESU when they were discontinued and I have them if you want some. Otherwise you can use the Accel plugs. You can call me.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 10 May 2010 09:20 by otakar.
  • otakar
10 May 2010 09:15
#367010
You Kenediens up there have to run those. Down here most of us don't even know what those are unless we ride a Touring bikes with a CB and a stereo. And even than we usually only run resistor caps. :P :lol:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • T_Dub
  • T_Dub's Avatar
10 May 2010 09:16
#367011
Otto you should take your number down, some bots will pick it up quick and you'll get inundated with African princes who want to share their fortunes with you.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • otakar
10 May 2010 09:22
#367012
Yah you'r right I never thought of that. I just PMd it instead.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
