Few Questions.
- ViciV
Few Questions.
03 Mar 2010 10:32 - 03 Mar 2010 12:03
Well today I picked up a go kart and it has a Kawasaki engine on it what i'm wondering is.
What kind of engine is this? the engine number is kz550AE052553
Also is the firing order 1243?
And in what order are the cylinders?
Sorry that my first post is asking for help but this seems to be the best place to ask.
Last edit: 03 Mar 2010 12:03 by ViciV.
- 79MKII
- Love Them Kaws!
Re: Few Questions.
03 Mar 2010 10:52
Looks like a KZ550, but someone will hopefully chime in that can confirm that and give some additional details.
Regarding the cylinder numbering, the Kaws are 1,2,3,4 from left to right when sitting on the bike.
By the way, post some pictures - we love pictures! :laugh:
The Kaw List:
- trianglelaguna
Re: Few Questions.
03 Mar 2010 11:05
No eBay APP ID and/or Cert ID defined in Kunena configurationit's a kz550-A3....
here is a link to a great book for it it is the factory shop manual....the best one.....and it is a fair/cheap going price imo....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- ViciV
Re: Few Questions.
03 Mar 2010 11:10
Thanks both of you. I'll post some pictures when my friend comes over. Hopefully Now I can get the thing sparking right.
- MFolks
Re: Few Questions.
03 Mar 2010 13:13
On the smaller 4's (I could be wrong) I believe the RIGHT ignition coil fires plugs #1 and #4 with #2 and #3 from the LEFT coil. On the bigger 4's is just the opposite with the LEFT coil firing #1 and #4 and the RIGHT doing #2 and #3.
The primary wires should be RED(going to both coils from the run/stop switch on the right handlebar) with either a BLACK or GREEN wire going to the coil(depending on how the electronic pickups are configured.
If the bike has the Kawasaki electronic ignition, the pickup coils are under a CD sized cover on the right side of the engine at the end of the crankshaft.
- ViciV
Re: Few Questions.
03 Mar 2010 13:38 - 03 Mar 2010 14:00
Well Its sputtering and popping. My friends dad said the timing is probably off. I wish I knew more about small engines lol.
Last edit: 03 Mar 2010 14:00 by ViciV.
- loudhvx
Re: Few Questions.
03 Mar 2010 15:57
The pickup with the black/blue wires trigger the spark for cylinders 1 and 4.
The pickup with the yellow/red wires trigger the spark for cylinders 2 and 3.
The pickup wires all go to the igniter box.
The 1 and 4 spark plugs are fired by the ignition coil with the black primary wire. (This coil would have been on the right side of the bike frame.)
The 2 and 3 spark plugs are fired by the ignition coil with the green primary wire. (This coil would have been on the left side of the bike frame.)
In order for all of that to work as it did from the factory, the pickup assembly and advancer/rotor assembly should be assembled as it came from the factory. (It often gets messed up after dissassembly for cleaning.)
Here's a link to the getting the pickup magnets correct and the rotor orientation correct:
home.comcast.net/~loudgpz/GPZweb/Ignitio.../PickupAndRotor.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- ViciV
Re: Few Questions.
03 Mar 2010 16:43
loudhvx wrote:
Thank you. She's up and running now! :ohmy:
