KZ1000P Generator Rated Output
- zrexerik
Anyone know what the rated output is?
- MFolks
- Thank you received: 540
I believe the GPz's have the same size stators as the cop Kz's
- zrexerik
The site you linked is currently out of stock for my bike and they list the same generator despite different Kawasaki p/n's. Still would like to know what the difference is between the stock generators.
- Samwell
- Thank you received: 1
I'd like to use my Gerbings heated clothing on my KZ1100B1, but the installed generator doesn't have the output needed. The later model KZ1000P's have a different rotor (stator and V/R are the same). I guessing the different rotor generates more amps than the one on my GPz and should bolt right on.
Your stator output is in the 250 to 280 watt neighbourhood. Don't feel too bad, my '78 has only 190 watts to work with.
Before you change your wiring, hook up the gear and with the bike running, check your voltage at the battery. If you can maintain 13.5 volts or so w/o blowing any fuses or your regulator getting too hot, then your alternator is up to the job.
my $0.02
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- MFolks
1. www.customrewind.com
2. www.rmstator.com
3. www.ricksmotorsportselectrics.com
4. www.regulatorrectifier.com
- zrexerik
I was assuming extra lights and loads on the police bike meant more alternator juice. Maybe the ~8 amps my Gerbings will draw is similar to the xtra loads on a police bike.
I'll check the output with the clothes plugged in and see what i get.
- Samwell
Thanks for the help. was hoping someone might have a manual with the alternator specs.
There's some good reading on other forums about stators and regulators. Apparently even modern bikes have issues. If you can find a heavy duty mosfet type reg/rect off of ebay, then you can wire it directly to the battery and get better overall performance. www.easternbeaver.com has the pre made conectors, and a write up about the type of reg you'd need.
- Old Man Rock
- Thank you received: 225
Just in case, contact and ask for spec sheets...
americanclassix.com/kawaElectrical.html
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
