replacing stock blinkers on 1980 kz 750 w/ LEDs
- bluferno
24 Feb 2010 06:53
Is is possible to replace stock blinkers on a 1980 KZ 750 H-1 LTD with led bullets. I'm getting mixed remarks from people but if I dabble with the correct relays if needed and use load equilizers the application should work right? I'm open to any suggestions and guidance.Has anyone out there done this.
Thanx Bryan
Thanx Bryan
- otakar
Re: replacing stock blinkers on 1980 kz 750 w/ LEDs
24 Feb 2010 06:59 - 24 Feb 2010 07:00
There is absolutely no problem doing it. I did it on my scratch built 82 GPz1150. Matter of fact, I do not have a SINGLE incandescent bulb on the bike anywhere. All you need to replace with the blinkers is the flasher units. Yes I said Units (2)! There is one for directional and another for emergency. The Flasher units are about $15 each. If you need help you can PM me.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 24 Feb 2010 07:00 by otakar.
- bluferno
24 Feb 2010 07:35
So all I need to worry about are the {2}blinker relays and not the load equalizers.The LEDs will be fine with the current voltage?Do I just step down to the next step in voltage for new relays {flasher units}?Thanx for your quick response.
- otakar
24 Feb 2010 10:14 - 24 Feb 2010 10:15
Just replace the existing flasher units with electronic ones. That is all. If you want some I have them. Last time I bought some I bought 6 to have some spares.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 24 Feb 2010 10:15 by otakar.
