Ic Igniter disassembly.
  • rstnick
  • rstnick's Avatar Topic Author
  • Premium Member
  • Premium Member
28 Mar 2006 06:23
#34895
My Igniter has a fault, I'm not getting a reading on the red wire. I thought if it's toast, I may as well open her up to see if I can find a loose wire or something.
Anyone ever had one of these things open?
The front and sides are metal, and the back is a soft flexable material. I tried carefully cutting along the edge to open her up, but it looks like the whole inner unit is encased in this soft material. Any ideas?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • steell
  • steell's Avatar
Re: Ic Igniter disassembly.
28 Mar 2006 07:14
#34909
It's called a conformal coating, there is some info available here
  • loudhvx
  • loudhvx's Avatar
28 Mar 2006 10:09
#34949
I opened one up. It's pretty interesting inside. They actually used surface mount technology. Even the transistors were layered onto the main plate. I don't think you'd be able to repair it, if that's the plan.
