75KZ400 stop lamp flickers or stays on
  • zoo
  • zoo's Avatar Topic Author
  • My 75 KZ400
15 Feb 2010 18:23
#348537
Hi all!
My 75 KZ400 has a flickering stop lamp and I cannot find any problems with the lights. Nothing seems to be blown, all lights work. Any ideas of what to do? A good cleaning or something?
Thanks in advance.....ya'll are awesome.
Tammy
Green Sea, SC
Quarter Horses & Iron Horses!
2009 Vulcan 500
1975 KZ400D
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: 75KZ400 stop lamp flickers or stays on
15 Feb 2010 18:48
#348540
My first thought is that the brake switch at the foot lever is maybe adjusted too sensitively.
You can just twist it to make it more or less sensitive.
B)
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • gane
  • gane's Avatar
15 Feb 2010 18:49
#348541
Zoo, Taillight or inst.light? Inst light comes on when brake light is on, & flashes if bulb is out when brake is applied (on applicible models) for grins, back off rear brake light switch adjuster @ 1/2 turn,check function & observe. luck G
[img][/img] 1977 KZ1000A1
15 Feb 2010 18:52 - 15 Feb 2010 19:11
#348542
As suggested by Biquetoast and gane, perhaps the rear brake switch is adjusted too sensitive, and could be loosened a tad.
Here's a pic of a typical rear brake switch.
Good Luck! :)
Last edit: 15 Feb 2010 19:11 by Patton.
15 Feb 2010 19:30
#348549
The "dashboard" indicator lamp in the panel between the tach and speedo may have a label underneath that says "Stop Lamp" in small white letters.
With ignition switched ON, the "dashboard" indicator lamp is normally off until it glows steadily during braking. But if "flashing" while riding along without braking, it's warning in advance that the rear brake light has failed and will not function upon subsequent braking. The failure might be due to a burned out bulb or some fault in the wiring.
The bike's rear light bulb is a dual filament bulb, meaning it has two separate filaments. One filament is the "brake" light supposed to burn only during braking. The other filament is the "tail" or "running" light supposed to burn whenever the headlight is on (or when ignition switch is turned counter-clockwise to "parking light" position). The tail light has no influence on the dashboard "Stop Lamp" indicator. And the dashboard "Stop Lamp" indicator gives no information regarding operation of the tail light.
Good Luck! :)
  • Biquetoast
15 Feb 2010 19:46
#348553
Patton wrote:
The "dashboard" indicator lamp in the panel between the tach and speedo may have a label underneath that says "Stop Lamp" in small white letters.....
Oh right... that...
It could also be flashing (with a regular meter, not intermittently flickering) if you replaced your tail/brake bulb with an LED bulb, since the warning module senses the load of a normal bulb, but cannot detect an LED bulb properly.
B)
kz750twins.com
  • soccerd31
  • soccerd31's Avatar
16 Feb 2010 14:27
#348652
i had a similar problem... i decided to run a new power source from the front of the bike... i could never pinpoint where the problem was with the tail light... my brake light has always been accurate... but.... the tail light would be on.. then off... i couldn't go night riding... after 2 weeks of day time playing with the damn thing... i just ran a new wire... if you decide to run a new wire make sure that its a hot wire that only will light up your bulb when the ignition is on.... otherwise you might end up with a dead battery in the morning... or... after you make a stop while out riding... and that would just SUCK!!!...
1981 KZ750 LTD H2
  • zoo
  • My 75 KZ400
16 Feb 2010 17:07
#348691
Thanks! I will check it out. Appreciate the quick response...
Tammy
Green Sea, SC
2009 Vulcan 500
1975 KZ400D
  • zoo
  • My 75 KZ400
16 Feb 2010 17:08
#348692
Thank you! I will check it out.
Tammy
Green Sea, SC
2009 Vulcan 500
1975 KZ400D
  • zoo
  • My 75 KZ400
16 Feb 2010 17:10
#348693
I am hoping I do not need new wiring but brakes lights and lights in general are pretty important. Thanks for your help.
Tammy
Green Sea, SC
2009 Vulcan 500
1975 KZ400D
