Gauge cluster swap..
  • Maitlandtron
  • Maitlandtron's Avatar Topic Author
09 Feb 2010 20:34
#347504
I recently purchased a 1983 GPz 550 but it is missing the instrument cluster. I tried looking everywhere for one but i was only able to find units for 84 and up. I don't mind using the speedo and tach from a an 84, even though I wiuldn't have any warning lights. I just need to know which is the signal wire for the tach. Does anybody have a wiring diagram for an 83 and an 84? Any help would be appreaciated. Thanks!
  • MFolks
  • MFolks's Avatar
Re: Gauge cluster swap..
09 Feb 2010 21:28
#347510
I have an 82 GPz1100 B2, with the electric tach that also becomes a voltmeter when a button is pushed on the instrument cluster. There will be three wires: A BLACK wire(probably the signal wire from the left ignition coil), A BROWN wire(probably a common wire to the instrument lights) and a BLACK with YELLOW stripe, the ground circuit found all over the bike.
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
10 Feb 2010 06:03
#347548
There is a wiring diagram for the 1983 GPz550 (and perhaps the 1984...but I didn't look) on this site. Go to the KZ Information tab above, then to the Filebase tab, then to the year button, then scroll down to your model and open the file there. :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • tsar
  • tsar's Avatar
11 Feb 2010 07:24
#347713
I have a set of gauges for a 83 GPZ in KMH if your interested.Check out this post I put up about a month ago:
kzrider.com/index.php?option=com_kunena&...ew&catid=4&id=342087
BIG MIKE
www.ironspartans.ca
Μολὼν λαβέ
______________________
1979 KZ1000ST
2001 HD Sportster 1200
1996 Vulcan 1500
Montreal,Canada
