Wanted Dyna "S" Plate
  • roy-b-boy-b
  • roy-b-boy-b's Avatar Topic Author
03 Feb 2010 15:19
#346275
I have a Dyna "S" that has a bad plate. I have two holes stripped out and i have tried everything to fix it.
I just need the plate the pulse coils mount to. Roy
  • Kawickrice
  • Kawickrice's Avatar
Re: Wanted Dyna "S" Plate
03 Feb 2010 15:33
#346279
If it were me I would try to use the existing plate. Maybe turn it and drill new holes for the pulse coils. I would lay it on a degree wheel for a reference point for 180 degrees across and tap my own holes. The plate is pretty simple.... with distance being the critical factor to the rotor
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Old Man Rock
  • Old Man Rock's Avatar
03 Feb 2010 16:09
#346287
Anyway to tap for the next size larger holes/screws...?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • roy-b-boy-b
03 Feb 2010 16:34
#346293
No,I have tried every thing. Even tried to sorder the holes.
I'll try and get one from dyna. Roy
  • Mark Wing
  • Mark Wing's Avatar
Re: Wanted Dyna
03 Feb 2010 18:07
#346327
I've got one for a 650.
Mark
Yorba Linda Cal.
  • roy-b-boy-b
Re: Wanted Dyna
03 Feb 2010 18:08
#346329
Should be the same? Roy
  • gane
  • gane's Avatar
Re: Wanted Dyna
03 Feb 2010 18:18
#346330
Any chance you could use stripped plate as a template, and transfer needed mount points to an OE breaker plate? G
[img][/img] 1977 KZ1000A1
  • roy-b-boy-b
Re: Wanted Dyna
03 Feb 2010 19:19
#346332
The only stock plate i have is a good one. Roy
  • nads.com
  • nads.com's Avatar
Re: Wanted Dyna
03 Feb 2010 19:23
#346334
650 has a smaller plate I tried it. Wasn't even close.
  • MFolks
  • MFolks's Avatar
Re: Wanted Dyna
03 Feb 2010 19:27
#346336
Might cost a little $ but ask local machine shops to weld the holes closed,drill and retap them. Is the plate aluminum?
They can possibly make you a new one, but again $
  • nads.com
  • nads.com's Avatar
Re: Wanted Dyna
03 Feb 2010 20:45
#346347
Can u just move the pickups and drill some new holes?
  • MFolks
  • MFolks's Avatar
Re: Wanted Dyna
03 Feb 2010 20:58
#346349
Another thought: PEM make a press in steel nut that might work for you. It locks in place after being swaged.
Ask around at the machine shops.
www.pemnet.com/fastening_products/prod_d...eners+for+Sheetmetal
