Rt handle switch.Which one is the original for Z1?
- tybolt99
- From where KZs came
31 Jan 2010 15:21
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
- MFolks
Re: Rt handle switch.Which one is the original for Z1?
31 Jan 2010 16:05
The one on the right I remember being on a 1977 Kz1000 I had, not sure about the one on the left, could be the correct type for the Z1.
- roy-b-boy-b
31 Jan 2010 16:52
There is a member that restores swithes for Z's
kzkrazy i believe. His name is Tim and he lives around Rochester,Ny.
- roy-b-boy-b
31 Jan 2010 16:54 - 31 Jan 2010 16:55
Last edit: 31 Jan 2010 16:55 by roy-b-boy-b.
- tybolt99
31 Jan 2010 17:16
Neither one of them looks like that one.:blink:
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
- Kawboy74
31 Jan 2010 17:23
I would say the one on the left is more correct, the one on the right looks the same as my '78 Ltd. The Canadian version did not have the headlight on/off switch as we had a daytime running headlight but the kill switch had a fatter red insert, also like the one on the left.
good luck!
good luck!
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
- Jeff.Saunders
31 Jan 2010 17:25
The switch in Roys picture is an early 1973 Z1 switch. The rounded area with the 'OFF RUN OFF' lettering shows it as a 73 switch, the throttle lock knob underneath shows it as a very early 73 switchblock.
The switchblock in the left side of your picture appears to be a 75 switch.
www.z1enterprises.com
Z1 Ent on Facebook,
- tybolt99
31 Jan 2010 17:39
Thank you, Jeff.
I will be calling Z1E once I start this project.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
