Dynatek Ignition Booster Worth the $$$ ?
  • bountyhunter
  • bountyhunter's Avatar Topic Author
30 Jan 2010 23:26
#345510
I have the 750 twin (B4) with points. The ignition has been getting a little iffy lately and I recently put on a new EMGO four Ohm coil I got from Z1 which seems to work well.
I was wondering if I should also add the Dynatek ignition booster:
www.dynaonline.com/skins/products/sportbikes/boosters/
I see these on ebay for $60 while being incorrectly listed as CD (capacitive discharge) units by the sellers. Dynatek does not call them CD, they just call them "boosters". They are actually "low side switch" solid state devices that have FETs or transistors of some kind to conduct the coil primary current to ground and use the points to fire the transistors. So, point current and wear goes way down and rise time of the coil primary current is faster which should give hotter spark. That is probably worth the $60.
Anybody use one of these guys? How big is the unit itself (can't get a dimensioned drawing)?
I was also wondering, do they prevent the DC current flow in the coil with the key on (but engine not running) that sometimes cooks coils?
Thanks
  • loudhvx
  • loudhvx's Avatar
Re: Dynatek Ignition Booster Worth the $$$ ?
31 Jan 2010 04:06 - 31 Jan 2010 04:12
#345521
Why spend $60 when you can make your own for about $15 to $20? One of the options is a time-out circuit to shut the ignition off after 5 seconds of non-use. The lower-priced Dyna ignitions tend to not have that option, but I'm not sure about their booster device.
Points to fire an HEI module.
The HEI module can withstand a primary peak of nearly 600v if I recall correctly. That will easily fire a stock KZ. You could use any coil down to about2.5 ohms without hitting the 5.5A current limit.
If you go lower resistance, you'll be hitting the curent limit, wasting power, and heating the HEI with no real gain.
With the long dwell on the points motors, a 3-ohm is probably better suited.
All of the HEI module details are in my notes. The HEI uses good old Darlington's. I have several bikes running them (driven by points and reluctors).
Last edit: 31 Jan 2010 04:12 by loudhvx.
  • bountyhunter
31 Jan 2010 10:34 - 31 Jan 2010 10:38
#345602
Laziness and this way it comes in a potted module that will withstand vibration better and has it's own mountinbg hardware and heatsink.
Last edit: 31 Jan 2010 10:38 by bountyhunter.
  • bill_wilcox100
  • bill_wilcox100's Avatar
31 Jan 2010 13:58 - 31 Jan 2010 14:00
#345641
bountyhunter wrote:
Laziness and this way it comes in a potted module that will withstand vibration better and has its own mounting hardware and heat sink.
I have never come across this product... cool. This could be a cost reduced solution for many riders.
For future reference this is the Pic and Data I found:
Best of success, :)
Bill
PS
If anyone who bought one of these could post the attached instructions and especially the wiring diagram that would be great.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 31 Jan 2010 14:00 by bill_wilcox100.
  • bountyhunter
31 Jan 2010 17:30 - 31 Jan 2010 17:32
#345708
You can download the PDF of the install wiring instructions here:
www.dynaonline.com/skins/downloads/Default.aspx
That's how I knew it's not a CD unit, the module ties to +12V but the + side of the coil primary does also. That means the module just switches the NEG side of the coil primary to ground.
Last edit: 31 Jan 2010 17:32 by bountyhunter.
  • bill_wilcox100
31 Jan 2010 18:42 - 31 Jan 2010 18:42
#345743
Again, for future reference this is the Installation Instructions:
Best of success, :)
Bill
Upgrades:
Montreal, Canada
Last edit: 31 Jan 2010 18:42 by bill_wilcox100.
