kz900 headlight troubleshooting.
- kbmotocross505
30 Jan 2010 18:49
Hey guys. i got my ignition turned on after like 20 years. but the problem is, when ever I turn on my headlight..it starts to make a rattling machine gun style sound...im thinking this is bad...What should i do? any tips on what to make it stop? its on a turbo bike so it's different.
- kbmotocross505
Re: kz900 headlight troubleshooting.
30 Jan 2010 18:51
ALSO where is the starter kit on it? I can't seem to find it. It's got a Mr> Turbo Kit set up on it.
- Kawickrice
30 Jan 2010 19:04
If you cant even start it should you really have a turbo?
Did you just get the bike? We want pics
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- kbmotocross505
30 Jan 2010 19:15
hey...i don't want to start it now because its getting restored. needless to say my gas tank is off and i need it sandblasted as well as a new fuel petcock so i don't want to start it 'till the fuel parts are back on new.
- Kawickrice
30 Jan 2010 19:17
you got pics? sounds like a nice project
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- MFolks
30 Jan 2010 19:44
If you follow the RED Positive(+) battery cable, it will lead you to the starter solenoid, from it a cable will go to the starter motor(usually under a cover right under where the left carb is).
I believe a 10mm wrench is all you will need to remove the cover. If you plan on removing the starter motor,get a new left side engine cover gasket as they usualy tear on removal.
If possible put the bike on the centerstand and tilt it to the right to minimize oil loss.
I believe the motor has maybe two gear reductions before getting to the crankshaft.
An overriding clutch with rollers and springs provide the torque to start the engine. This clutch is behind the alternator rotor and it will be needed removed.
www.z1enterprises.com should be able to get you new overunning clutch parts.
- kbmotocross505
30 Jan 2010 20:34
Thank you very much MFolks. I will do that, but to the others who want to see a picture of my KZ. go on my Profile and go to my gallery..enjoy. comments would be appreciated.
- Old Man Rock
31 Jan 2010 02:36
"i got my ignition turned on after like 20 years. but the problem is, when ever I turn on my headlight."....
Possible miss wiring or the electrical system such as a regulator is oscillating due to the extra current demand may be the issue... Ignition switch on, no issues, only when headlight turned on... :huh:
This sound, can you track it down to where it's origin is?
Is it the run signal relay chattering on/off?
Just in case you need...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
