coil output
  • michigans
  • michigans's Avatar Topic Author
coil output
26 Mar 2006 18:02
#34527
i am getting 11.4 v. going into the coils and 12.3 v at the battery terminals. would it be worth doing the electrical modification i see on here all the time. or should i just wait until something happens
  • N0NB
  • N0NB's Avatar
  • Blue handles better
Re: coil output
26 Mar 2006 20:09
#34582
I would think the mod would be worthwhile. A drop of 1 volt before the coils is quite a bit.
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • Scotty355
  • Scotty355's Avatar
Re: coil output
27 Mar 2006 14:22
#34731
I had about the same drop in voltage and did the mod my 750 now starts alot quiker and sounds smoother I have not been able to take it for a ride yet but it seems to have made a differance.
  • giftofthegods77
  • giftofthegods77's Avatar
Re: coil output
27 Mar 2006 21:13
#34844
There's been so much hoopla about this coil mod that I am thinking about doing it myself. My bike is hard to start, although it does start.
My question is this: Is there a reason to NOT do the WG coil mod?
Thanks
  • KZQ
  • KZQ's Avatar
  • Away
  • Administrator
  • Administrator
Re: Yes!
28 Mar 2006 05:34
#34886
The coil mod involves bypassing an number of electrical connections that may be corroded. I've never had any problem identifying the bad connections and cleaning them up. If you add a side circuit you will probably help the coils but what about the rest of your bike's electrical system. As a short term fix it's fine but no substitute for good maintence.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Yes!
29 Mar 2006 06:45
#35145
Bad connections and corrosion should be cleaned. I suggest that worn contacts in the ignition switch and kill switch are not exactly the same issue. They are worn and perhaps not corroded. I suggest someone write an article on how to restore worn contacts. I actually wrote one on restoring the kill switch some time in the past but have no idea what happened to it on the old site. It is pretty much a pain as the plastic trough inside the kill switch that the ball bearing rides in wears deeper and the detents don't engage as positively as when new. The ignition switch can similarly be disassembled (watch out for small springs and ball bearings) but once in there, if the the copper contacts are worn, you can really only replace the entire switch unit. Now if you have an ignition switch and kill switch which are in good condition and all that is wrong is corrosion in the connectors, DO NOT bypass cleaning all connectors on your bike as there will be corrosion present that will dimish the bike's starting ability, the ability to charge and make other electrical components operate erratically (lights/horn etc).
