Switch, outage indicator
- gvstenst
25 Jan 2010 00:33
Rebuilding my Kz1000 found the outage indicator switch attached to the coils, looks like it may not have been connected and looks bad (cover with engine gunk and all) don't know if it works. Apparently not available anymore part # SKU28019-001????
How important is this thing?
Anybody know where to get a replacement?
Thanks
Thanks
- Old Man Rock
Re: Switch, outage indicator
25 Jan 2010 05:24
Without knowing your exact year and model.. E, G etc...
Hard to say but I believe your speaking of the Brake Light Failure Indicator switch....
Has 3 conductors to a connector: yellow, green & black?
If the above holds true, all this device does is sense when the brake light bulb goes out and turns on the instrument cluster lamp indicating so... In which case, nice to have sure but the bike should be able to run with out it connected.
As for where to possibly find a new replacement, unknown....
Hope this helps...
OMR
Hope this helps...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- gvstenst
