Fried electronics
  • Becker
  • Becker's Avatar Topic Author
  • The Doctor Will Rise Again
Fried electronics
20 Jan 2010 14:39
#343632
So I was in a hurry before I left home this weekend and I was trying to get my friends 1978 KZ650 C2 with a 1977 650 B motor. It was in a barn that was definitely sub zero in temperature. The battery was probably dead too so I tied a rope around the steering head and tied the other end to the back of the prowler. I then had my little brother pull me while I dropped the clutch. It worked and the bike started. But after that I lost all the electronics. Lights, turn signals, everything. Except, the engine was still running. I had to leave immediately afterward so I never had time to check for anything being wrong.
Any idea what happened?? I'm thinking it had something to do with the battery being frozen?? What would you guys check first??
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • MFolks
  • MFolks's Avatar
Re: Fried electronics
20 Jan 2010 15:06
#343636
I'd get a new battery and try again. I've read that a dicharged battery will freeze ruining it for future use.
If the engine still runs, I'd check the fuses and electrical connectors for corrosion as these usually become intermittent.
Make sure the heavy duty cables going to the battery terminals and to the engine mounting bolt are clean and tight.
  • MFolks
  • MFolks's Avatar
20 Jan 2010 15:09
#343637
Fuse And Fuse Holder Designations
1. The older Kawasaki’s use a glass tubed fuse with the designation of AGX 1” long. Most good auto parts stores can get them for you. They are ¼” in diameter.
2. The more common AGC is 1 ¼” long and may not fit the smaller fuse clips. Again, ¼” in diameter.
3. To clean and polish the fuse clips, I use a cotton swab(Q- Tip) and some Brasso metal cleaner or Turtle Wax Chrome Polish. I suppose any good metal polish would work.
4. These fuses can fail internally but look good, only by removing them from the clip and electrically continuity checking with either a self powered test light, or a multimeter set on OHMS can they be determined to be in good shape.
5. A physical inspection of the metal end caps for tightness will tell you if the fuse is serviceable.
6. Most modern motorcycles are now using the automobile “Blade” style fuse with the designation of ATC or ATO.
7. The reduced sized “Mini” Blade style fuse holder uses the ATM size of fuses.
8. If the fuse and fuse holder overheat, it could soften or anneal the grip of the clip, it might require squeezing the clip to restore the tightness.
9. A list of where to purchase “Blade” style fuses and holders:
www.waytekwire.com
www.rallylights.com
www.delcity.net
  • keith1
  • keith1's Avatar
20 Jan 2010 15:13
#343638
new battery.....
  • bountyhunter
  • bountyhunter's Avatar
20 Jan 2010 15:40
#343642
Running a bike or car electrical sytem with a bad battery attached can destroy many parts of the electrical system. The battery acts as a large capacitor to smooth the AC pulses coming from the alternator. A frozen or otherwise toasted battery has a high impedance and won't act like a capacitor and the electrical system will get hit with high voltage transient spikes.
I kick started mine one day on a bad battery (open cell) and took out half the electrical system....
  • RonKZ650
  • RonKZ650's Avatar
20 Jan 2010 15:58
#343645
If the battery is missing, or otherwise open circuit, every bulb will burn out within a few seconds if the engine is started.
  • trianglelaguna
  • trianglelaguna's Avatar
20 Jan 2010 19:13
#343690
learn somthing everyday.....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Kawickrice
  • Kawickrice's Avatar
20 Jan 2010 19:21
#343694
The bike is still running so that is a good sign. Put in a new battery check all your fuses. When you get it running again check to see if you have 14.4 volts to the battery with the rpm's at about 4000. That will let you know if the charging system took a hit.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Becker
21 Jan 2010 18:19
#343811
I really hope I didn't fry it all. I'll try switching out the battery when I get home and see if it comes back. Fingers crossed.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
