KZ750E1 - Any replacement for I.C. Ignitor?
  • po boy
  • po boy's Avatar Topic Author
16 Jan 2010 19:50
#343173
Mine's dead. Otherwise great bike is useless.
Anyone know of a substitute or suitable replacement from another model?
One to sell?
Got a mean itch to ride....
1980 KZ750E1
2002 Hayabusa
  • JMKZHI
  • JMKZHI's Avatar
Re: KZ750E1 - Any replacement for I.C. Ignitor?
16 Jan 2010 19:54
#343174
From the cross-reference at Kawasaki.com:
1980 KZ750-E1 (Standard-4)
Igniter 21119-1040
Model (20):
KZ1000-G1 (Classic) (1980)
KZ550-A1 (1980)
KZ550-A2 (1981)
KZ550-A3 (1982)
KZ550-A4 (1983)
KZ550-C1 (LTD) (1980)
KZ550-C2 (LTD) (1981)
KZ550-C3 (LTD) (1982)
KZ550-C4 (LTD) (1983)
KZ550-D1 (GPz) (1981)
KZ550-F1 (Spectre) (1983)
KZ550-M1 (LTD Shaft) (1983)
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-H1 (LTD) (1980)
KZ750-H2 (LTD) (1981)
KZ750-H3 (LTD) (1982)
  • RonKZ650
  • RonKZ650's Avatar
16 Jan 2010 20:08
#343175
Dyna-s or Dyna-3 are the best bet. I'm a stock guy, but the ignitor is horribly expensive if you can get it and dyna works just fine.
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
16 Jan 2010 20:12 - 20 Feb 2013 19:04
#343176
Last edit: 20 Feb 2013 19:04 by H1Vindicator.
  • MFolks
  • MFolks's Avatar
16 Jan 2010 21:16
#343177
If your ignition pickup coils are good, and the bike has a mechanical ignition advancer, build you a replacement like this:http://home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html
  • loudhvx
  • loudhvx's Avatar
16 Jan 2010 23:04
#343181
The link to my site seems to only work if it's inside the url tags.
  • H1Vindicator
Re: ----
17 Jan 2010 07:48 - 20 Feb 2013 19:04
#343202
  • po boy
17 Jan 2010 08:08
#343205
Thanks for the help so far guys.
The idiot I bought this bike from didn't put the overflow tube on the battery and acid got all over a bunch of stuff.
The bike started to miss as you would ride it and that got progressively worse. Now I get no spark and everything else checks out o.k.
I'm leary of buying used electrical parts normally so I was hoping to see what it took to make the part I need.
1980 KZ750E1
2002 Hayabusa
  • loudhvx
  • loudhvx's Avatar
17 Jan 2010 12:01
#343232
H1Vindicator wrote:
From the GM HEI Ignitor Substitute:
The module was installed in 8/05. The module currently (as of 8/07) has several thousand miles on it. If any reliability issues come up, I will update this page.
Lou, any updates? Thanks.
Still working great... I have the HEI modules on two bikes now and both seem to be working flawlessly so far.
  • polkat
  • polkat's Avatar
17 Jan 2010 12:11
#343233
We used to use the GM modules on our Mopar V-8's (sort of as a cheap alternative to the MSD stuff). They work great and theoretically provide a hotter spark as well. I like this idea and will do it to my 750 even though it doesn't need it!
  • MFolks
  • MFolks's Avatar
17 Jan 2010 12:17
#343234
I've posted it before, but here's a cross index for the GM electronic module from several manufacturers:
HEI Ignition Modules (4 Pin)
AC DELCO
DM 1906 or D1906
WELLS
DR 100
ACCEL
ACC 35361/ACC 35367
PERTRONIX
D2000
CAR QUEST
21040
NAPA ECHLIN
ECH TP45
NIEHOFF
DR 400
BORG WARNER
Select CBE4/CBE22
GM
10482820
Mallory
607
Jegs
555-40600
Moroso
97857
