Carburetor
  • ndfez
  • ndfez's Avatar Topic Author
Carburetor
10 Jan 2010 17:58
#342496
Could I put a Kz1000 Carb on my Kz750?If so would I have to do any modifiying?
  • TerryK
  • TerryK's Avatar
Re: Carburetor
10 Jan 2010 18:14
#342500
I believe the spacing is wider on the 1000 carbs.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Carburetor
10 Jan 2010 18:21 - 10 Jan 2010 18:22
#342503
What years/carbs are we comparing here? Both models came with different types/sizes of carbs throughout the years I believe.
Generally, yes you can. It will affect the performance, and likely not for the better without modifications.
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 10 Jan 2010 18:22 by TeK9iNe.
  • ndfez
Re: Carburetor
14 Jan 2010 10:33
#342869
Thank you saved me a costly mistake.
  • ndfez
Re: Carburetor
04 Mar 2010 08:54
#351226
What year are these carbs an what kawasaki bike do they go on,Kei Hin v153 wk17?
  • otakar
  • otakar's Avatar
Re: Carburetor
04 Mar 2010 09:01 - 04 Mar 2010 09:03
#351229
The KZ-650/700/750/900/1000/1000J/1100 all have the same carb spacing. The GPz750 used the same carbs as the J model 1000 & 1100 albeit they had totally different jetting. Guys swap these carbs all the time. All it requires are different manifold boots and re-jetting. As long as you stay away from the Keihin carbs and stick with Mikuni you should not have any problems that can't be resolved with ease.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 04 Mar 2010 09:03 by otakar.
