starter button to solinoid
- kaw1425
09 Jan 2010 20:35
can any one tell me how to hook the starter button to the starter solinoid on a kz 900i can jump the starter and it will start push the handle bar button and wont do nothing
- MFolks
Re: starter button to solinoid
09 Jan 2010 22:55
I'd do this:
1.Disconnect the Negative(-) battery terminal.
2.Open up the right handlebar switch housing.
3.Check for broken wiring or dirty contacts on the start switch.Spray on electrical cotact cleaner should remove the corrosion(NOT WD-40!!!)Watch out for flying springs too.
4.If everything looks good inside the switch, open up the headlight housing and see if some wires are disconnected.
5.I believe two black wires go to the start switch, so check both for being connected.
6.Reconnect the Negative battery terminal and try again.
- Old Man Rock
10 Jan 2010 04:52 - 10 Jan 2010 04:54
With a DVM (Digital volt meter)....
Set meter to +20Vdc range (unless auto range sensing)...
Black probe to ground (chassis if well grounded or Batt (-) terminal)...
Red meter probe to red conductor on starter switch.
You should measure +12Vdc or battery voltage... Yes/No?
NOTE: Emergency On/Off switch must be working correctly!
Yes, then press starter button and you should measure +12Vdc on black conductor (not sure of this exact color but...) fed to starter... Yes/No?
If yes, then measure at starter Black conductor from starter switch... Should measure +12Vdc Yes/No...
If yes, then check black conductor terminal for oxidation, rust, build up etc... Clean/replace and re-try.
If not, then switch is not receiving +12Vdc from emergency switch... Note, this is the same voltage supplied to coils!....
Here's the schematic/wiring diagram fro a 1976 KZ900-A4... should be ~ the same for not sure of your year and eaxct model number....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 10 Jan 2010 04:54 by Old Man Rock.
