Rewrapping wiring harnesses?
- polkat
08 Jan 2010 16:43
I did some mods to my wiring harness that required removing some of the outer wrapping. Now I'm ready to wrap it back up, but I am not sure what kind of tape to use. I've been told not to use plastic electricians tape, as it reacts to heat and oils. I'm not looking for the split loom type stuff. Okay, then what is a good tape to use?
- loudhvx
Re: Rewrapping wiring harnesses?
08 Jan 2010 17:03
I've used regular electricians tape for decades with no problems except one... it's a real pain to un-wrap. What you really want is electrician tape without the adhesive... which is what the factory used.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
08 Jan 2010 17:30
- MFolks
08 Jan 2010 21:14
Some more tape sources:
Dry Vinyl Tape From Tape Brothers
www.tapebrothers.com
Dry Vinyl Tapes are non-adhesive plasticized polyvinyl chloride film tape. Easy unwinding characteristics - tape clings firmly to it’s own backing for tight wrap. High elongation and good strength to permit trouble-free binding of wiring harnesses for the automotive industry. Dry vinyl tape also used for plating applications- high stretch, good “cling†characteristics and great conformability provide for superior masking in hard chrome and other plating applications.
DVT-76B 2 in. x 250 ft. Black Dry Vinyl Tape
Our Price: $6.54 Per Roll
www.wiringharness.com
• Non-Adhesive Vinyl Harness Tape, made to the original mil-thickness.
• Just wrap it tightly around the wires and knot the end.
• 100 foot roll is enough to do 3 to 4 harnesses complete.
• Available in three different widths, as original.
• Correct for all years (1955 to Present).
Part # Description Price
R0058272 3/4" Vinyl Harness Tape, 100 foot roll $12.00
R0058276 1" Vinyl Harness Tape, 100 foot roll $13.00
R0067108 1-1/4" Vinyl Harness Tape, 100 foot roll $15.00
www.keefeperformance.com/silicone_tape.html
"36 Foot" roll of Self bonding silicone tape
High temperature silicone tape
This Mil-spec silicone tape is Rated up to 500+ degrees
Made of silicone rubber, this self fusing silicone tape will protect most all electrical wiring, connectors, hoses, spark plug boots and more from extremely high temperatures. The self vulcanizing process automatically begins when the two sides of the tape are put into contact. A catalyst on one side of the tape begins the bonding process as soon as wrapping takes place.
great for all electrical wiring, harness, cable, and hose applications
Colors: Red and Black
Exceeds MIL AA-59163 TYPE 1 & 2
ASTM-D 2137 / -65C
ASTM D-412
ASTM D-149
Electrical, Home, Auto, Truck, RV, Marine, Motorcycle, Military, Commercial, Industrial, Generator
ASTM-D 2137 / -65C
ASTM D-412
ASTM D-149
- PLUMMEN
08 Jan 2010 21:46
3M super33 is the brand i reccomend for anything you want to stay put,its about $3 a roll but it dont fall off.
- polkat
- fixer5000
09 Jan 2010 05:30
i agree with plummen super 33 is the best electrical tape out there
1978 kz650b pretty much stock
massachusetts
massachusetts
- RonKZ650
09 Jan 2010 07:52 - 09 Jan 2010 07:53
Don't use adhesive black tape. It's a mess. Use the dry tapes mentioned. You can get them at any place that does auto restoration supplys like "The Eastwood Co". Wrap the loom with the dry tape, then use the 3M regular tape at the ends to keep the whole works from unraveling. Comes out nice and easily reversable if need be plus much more flexibility since the tape is not holding the wires ridged, they are more or less floating in the loom. Try reversing a loom wrapped with adhesive tape, Yuk.
Last edit: 09 Jan 2010 07:53 by RonKZ650.
