- Thank you received: 4
KZ 750 Troubleshooting
- Grantl
- KZRider is Da Bomb!!!
23 Jan 2010 19:28 #344194
by Grantl
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
Replied by Grantl on topic KZ 750 Troubleshooting
Congratulations on your progress. The first couple of times you run the bike you might have some dark smoke coming from the exhaust. This might just be oil that has trickled down into the cylinders and is pooled around the rings. This should burn off after a couple of minutes of running the engine. This could explain the wet plugs but it is more likely that you have one or more carbs gummed up and your pumping too much liquid gas into the cylinders. You may want to give the carbs a good going over and install an inline gas filter.
The fact that the bike starts after a few kicks and runs smoothly with no backfiring suggests that the timing is not too bad.
Keep working the issues as they come up, and keep asking questions--these guys will help you a lot.
best of luck,
Grant.
best of luck,
Grant.
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
- MFolks
- Thank you received: 540
23 Jan 2010 20:24 #344211
by MFolks
Replied by MFolks on topic KZ 750 Troubleshooting
If you have to run the engine for a while(longer than say, 6-8 minutes) get a fan to keep it relatively cool.
These air cooled engines will overheat during prolonged idleing possibly developing a head gasket leak or more damage.
