settiing up speedometer pickup
- cary
23 Mar 2006 19:09
can an electric speedo pickup be mounted onto a wheel and fork setup for a mechanical speedo? this would be a KZ 1000 J pickup and gauges, on an '82 spectre 750 wheel and '82 kz750 forks setup (hell, with all this mix'n'match I'll just be glad when it rolls
- KZQ
- Administrator
Re: settiing up speedometer pickup
23 Mar 2006 20:11
Probably not. But you can use any number of after market speedometers that use magnetic pickups. Another solution is a bicycle speedometer. The better ones are programmable for different size wheels and go well into triple digits.
Good luck
KZCSI
Good luck
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- btchalice
24 Mar 2006 04:50
the electric pickup mounts exactly like the mechanical but make sure you get the small blade type insert that drives the speedo from the wheel that has electric. its held in with a snapring i put one on a spoke wheel
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
