electrical gone?
- phishphan
electrical gone?
23 Mar 2006 15:44
Well, I reassembled the entire electrical system last week. When I took it apart, I labled everything so it would help me on the rebuild. I put it all back together that way and everything was working before I took it apart. Well I hooked the battery up to it today and the headlamp would not light, I tested to right turn signal and it worked OK, then i tested the left and the neutral light and the headlamp warning light blinked....WTF???? After that, the entire system shut down and I can't get it back up....it looks like a fuse was blown.... any ideas on where to start or where i can get wiring diagrams?
- steell
Re: electrical gone?
23 Mar 2006 17:33
I don't know if it will help any, but Loudhvx has a wiring diagram for an 81 GPz550 on his site.
www.geocities.com/loudgpz/
- Vter Bob
23 Mar 2006 20:46
Greetings from the home of Phish. You say you have an 82 KZ550 LTD C2. I believe an 82 LTD would be a C3. The 81 LTD was a C2. Anyways...I have an FSM and if you like I will scan the correct wiring diagram and e-mail it to you. PM me with an address and let me know if you can read PDF format.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
