83'kz550gpz does anyone have a wiring diagram?
- MOOSECTW
07 Dec 2009 22:42
I chopped the bike and now their is my homemade wire harrness which is all fine but i am no electrican and i have everything done except the starter wants to run full time when the key is on run now their isnt a start/stop switch besides the key switch so i would be very gratfull if someone could through me a bone with a link to a diagram that can help me get this figured out thanks.
- MFolks
Re: 83'kz550gpz does anyone have a wiring diagram?
07 Dec 2009 23:01
On most of the older Kawasaki's, the starter solenoid that pulls in and energizes the starter motor is controlled by the right handle bar run/stop switch.
When the ignition key is turned on and the switch is pressed, the starter solenoid coil is energized. Sounds like a switch is missing or a wire is pinched/shorted causing the starter motor to run.
I have an 82 GPz1100 B2 and except for having FI on my bike, I believe the wiring and color codes are similar.
Looking at my bike's shop manual I see two BLACK wires going to the start switch. If these are pinched/shorted the starting solenoid will be "on" every time the key is turned on.I'd suggest looking for these wires before tearing into the main harness.
- MOOSECTW
08 Dec 2009 15:28
the bike dosent have the stock switch it has an after market 4 pole ignition switch batery acc. ing. starter and i cant figure out how to bypass putting a starter switch other than the key?
08 Dec 2009 17:37
Here's a link to the on-site 1983 KZ550H2 wiring diagram that might possibly help.
After clicking on link, may scroll to bottom of screen and download.
kzrider.com/index.php?option=com_docman&...w&gid=201&Itemid=108
Good Luck!
Good Luck!
