help...positive ground...?
  • hammerguy09
  • hammerguy09's Avatar Topic Author
03 Dec 2009 19:36
#337368
hello...ok i have a 78 kz1000 it was striped down and just has the bobber basics. The battery i got with it was shot so i just picked up a new one...tried to connect new battery and it sparked and burnt a wore down to the rectifier. I replaced the rectifier and tried to hook everything back up...initially the positive terminal of the battery was grounded to the engine case. I had never heard of this and thought it was a mistake...thought that might have been what burnt up the wire. When i connected everything again with the new battery and rectifier i put the ground to the negative terminal of the battery....nothing happened when i turned on the ignition. just wanted to know if it is supposed to be positive ground...and if so how that works...or maybe if something else burnt out...regulator...? Please help...thanks
  • MFolks
  • MFolks's Avatar
Re: help...positive ground...?
03 Dec 2009 20:49
#337379
Most if not all of the Kawasaki's I've seen/rode have/had Negative(-)Ground. The Positive (+) battery cable usually goes to the starting solenoid on one side and the other side to the starter motor.
When the start button is depressed/pushed,the solenoid energizes completeting the current path so the starter motor rotates starting the engine.
I'd suggest checking the fuses for open/blown fuses and then the wiring for signs of overheating/damage.
  • hammerguy09
03 Dec 2009 21:27
#337383
it only has a kick start
  • bountyhunter
  • bountyhunter's Avatar
03 Dec 2009 22:08
#337385
I have never seen any vehicle made in japan use a positive ground system. Most of the older British cars were positive ground. I believe that since the brits drive on the wrong side of the road, they have to reverse the battery to keep the electrons from getting confused.:laugh:
I built old Jaguars and MGs and their electrics were a trip. They were designed by Lucas who rightfully earned the name "prince of darkness" for his exploits designing car electrical systems.:laugh:
  • bountyhunter
03 Dec 2009 22:11
#337386
They sometimes have internal fusible links in main power wires that may have fried. God only knows what cooked if the battery was reversed: that's the danger of having a battery that can deliver about 500 Amps..... I would guess the rectifier/regulator could be toast.
  • Martynbiker
  • Martynbiker's Avatar
  • 1993 KZ1000P
03 Dec 2009 22:30
#337394
The problem is you have let the magic smoke escape, once the smoke escapes its kaput.:laugh:
seriously, start looking for a short somewhere before you put another battery on. and if polarity has been reversed, the rectifier is toast.
martyn
If you cant fix it with a Hammer....... it's gotta be an Electrical problem...
