ignition swap from kz650f to kz650b
  • vict182
  • vict182's Avatar Topic Author
30 Nov 2009 09:10
#336692
Hi all
I'm restoring a kz650b
I have a kz650f sitting for spares
how easy would be to take the ignition parts from the F and replace the points system from the B?
i mean, which parts should i replace?
thanks
  • loudhvx
  • loudhvx's Avatar
Re: ignition swap from kz650f to kz650b
30 Nov 2009 10:59
#336706
You need the coils, the timing plate with pickups, the advancer rotor, and the igniter.
This is assuming the f uses mechanical advance. If the f uses electronic advance, I'm not positive the pickup plate will fit in the motor, possibly with a little modification.
  • RonKZ650
  • RonKZ650's Avatar
30 Nov 2009 13:26
#336723
In the USA the F still used points.
  • rstnick
  • rstnick's Avatar
30 Nov 2009 17:25
#336741
Here's a post showing how I converted a kz1000 electronic igniton to fit an early kz650; kzrider.com/index.php?option=com_kunena&...iew&catid=4&id=12453
I have since switched to an '80s kz650 eletronic pickup plate.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
