LED markers and brake light
  • 9am53
  • 9am53's Avatar Topic Author
  • homebrew, and some bbq
23 Nov 2009 11:58
#335393
When I put my new ducktail on my bike I want to eliminate the rear fender and use an LED brakelight. Is this just a matter of wiring the light in? LED turn markers need a modified flasher relay don't they?
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
Re: LED markers and brake light
23 Nov 2009 12:05
#335394
correct!
  • Old Man Rock
  • Old Man Rock's Avatar
23 Nov 2009 13:02
#335398
Yup... LED sensing relay is the prefered method...
Don't fall for the added resistance route for your trying to decrease your loads and current demands not add to it...;)
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • 9am53
23 Nov 2009 14:48
#335410
kuul, thx
  • bountyhunter
  • bountyhunter's Avatar
23 Nov 2009 15:19
#335421
I recommend the Luxeon 3W LED for the tail/brake light so it will be bright enough.
superbrightleds.com
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
23 Nov 2009 16:20 - 23 Nov 2009 16:21
#335438
I bought my LED tail/brake light at a truck stop when they were on sale. 98 diodes. Straight wired to the stock system. Roy
Last edit: 23 Nov 2009 16:21 by roy-b-boy-b.
  • otakar
  • otakar's Avatar
23 Nov 2009 16:35 - 23 Nov 2009 16:36
#335441
Here is the light I built for my GPz. The one on the left is the original and the one on the right I built.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 23 Nov 2009 16:36 by otakar.
  • otakar
  • otakar's Avatar
23 Nov 2009 16:37
#335442
This is what it looks like from the back once again the one on the left is the original.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
23 Nov 2009 16:46 - 23 Nov 2009 16:48
#335444
I got my electronic flasher unit at AutoZone for about $3
it is called BLAZER 552/536LL It has now been on the bike for over two years working perfectly. Because my running lights and turn signals are also LED, I have one on the Emergency flasher circuit also.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 23 Nov 2009 16:48 by otakar.
  • 9am53
23 Nov 2009 18:52
#335489
thanks a lot, so is that flasher used instead of the old one, or is it wired some other way?
  • otakar
  • otakar's Avatar
23 Nov 2009 19:31
#335510
Just unplug the old one and plug in this one. It takes longer to get it out of the rubber mounting boot. :P
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • MFolks
  • MFolks's Avatar
23 Nov 2009 19:35
#335512
On some of the older Kawasaki's a four way flasher is used to flash the front and rear turn signals in a warning/hazard situation when a switch is thrown (usually on the left handlebar switch pod).
A regular turn signal flasher operates the front and rear turn signals,so there are two flasher cans in the electrical system.
