turn signal wiring
- OregonMatt
turn signal wiring
21 Nov 2009 12:25
so I have replaced the main wiring harness on the 900. The one that was in it was pretty hacked up with different splices and connectors and various other garbage, it was going pretty smooth until I got to the headlight area. I need to know what color wires do the front turn signals plug into? any help would be great.
1976 kz 900
- MFolks
Re: turn signal wiring
21 Nov 2009 14:45
If your bike has front running lights built into the turn signals, I'd imagine that these colors will work.
Out of the main harness for the LEFT front turn signal/running light:
BLUE, the running light circuit.
GREEN, the turn signal circuit
BLACK with YELLOW stripe, the ground circuit.
____________________________________________________________
Out of the harness for the RIGHT front turn signal/running light:
GREY, the turn signal circuit.
This was taken from the shop manual for my 82 GPz1100 B2 so the wire colors should still work.
- Old Man Rock
21 Nov 2009 15:14
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- OregonMatt
21 Nov 2009 17:08
Thanks, I have a wiring diagram, but was having trouble following the colors
1976 kz 900
21 Nov 2009 21:19
Grey to right turn signal.
Green to left turn signal.
Good Luck!
Good Luck!
