Can you turn back a speedo ?
- GregZ
20 Nov 2009 08:08
I'm just curious about this. I am replaceing a Z1 speedo with a nicer one but it shows alot more miles then the bike has. Can it be turned back??
- otakar
Re: Can you turn back a speedo ?
20 Nov 2009 08:27
Yes it can, I did it many times. There are multiple ways. The simplest is to run it backwards. Just do not do it too fast.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- RonKZ650
20 Nov 2009 08:58
You can use a drill. Get an old inner piece of cable or make your own and chuck it up in the drill. Turn the drill on in the direction the needle indicates MPH to see how fast the drill turns. If it's not excessive, like over 100mph, reverse the drill to run the speedo backwards. Of course this takes many hours. If you're going 100mph in reverse obviously it will take 10hrs to remove 1000 miles. I forget how many miles I had to remove once, but I had a drill running for several days straight believe it or not. Drill has a lot of miles on it.:laugh:
- Kawickrice
20 Nov 2009 10:30
I have done the drill thing to. It does take a while though
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- flht1997
20 Nov 2009 11:02
you can use those little square drive bits for those screws that carpenters use. just about the same size. my craftsman drill goes about 25 mph. my air drill goes about 90
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- jordan
20 Nov 2009 12:24
The ways listed above sound much easier than what i did. I had a kz650 tach that i wanted to use on my new 810 build. I set the tach back to 0. It was a very tedious process, but it worked very well. If you do it this way, make sure you do it in a small space where u will be able to find the parts that come shooting out all over
. I pulled the tach in half (had to slightly pry all around the part where the halves are pressed together). Then when you find the tach wheels, there is a small circlip deal that holds them on the shaft. remove it, pull the wheels off, turn them to zero(or whatever you want it at), then reassemble. Getting the circlip back on was the most difficult part. Then when reassembling, do a nice job of pressingt he 2 halves back toghther and pinching the seam back tight. prolly took about an hour total.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- mark1122
- Keep twisting it
20 Nov 2009 14:44
jordan wrote:
Ditto:)
The ways listed above sound much easier than what i did. I had a kz650 tach that i wanted to use on my new 810 build. I set the tach back to 0. It was a very tedious process, but it worked very well. If you do it this way, make sure you do it in a small space where u will be able to find the parts that come shooting out all over. I pulled the tach in half (had to slightly pry all around the part where the halves are pressed together). Then when you find the tach wheels, there is a small circlip deal that holds them on the shaft. remove it, pull the wheels off, turn them to zero(or whatever you want it at), then reassemble. Getting the circlip back on was the most difficult part. Then when reassembling, do a nice job of pressingt he 2 halves back toghther and pinching the seam back tight. prolly took about an hour total.
Ditto:)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- GregZ
20 Nov 2009 17:04
I think it's safe to say it is going to stay the way is. I don't have the patience for either method.:S
- JMKZHI
21 Nov 2009 06:54 - 21 Nov 2009 06:54
If you'd like to keep an accurate record (& proof) of the bike's mileage, take a photo of the stock speedometer prior to removal & one of the replacement meter before & after installing it. And a photo of the two together w the stock one still on the bike. Etc.
Last edit: 21 Nov 2009 06:54 by JMKZHI.
