coil mod help
  • bullitt
  • bullitt's Avatar Topic Author
coil mod help
20 Nov 2009 08:08
#334835
is there some where on here a diagram of
wiredgeoges coil mod not very clever with tech stuff
but willing to give it a go seems to have rave revues
when its done cheers
  • otakar
  • otakar's Avatar
Re: coil mod help
20 Nov 2009 08:32 - 20 Nov 2009 08:34
#334841
Just one of many.
kzrider.com/index.php?option=com_kunena&...ew&catid=4&id=332289
Do yourself a favor and read the entire thread, just so you know what it is and more importantly what it is not.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 20 Nov 2009 08:34 by otakar.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: coil mod help
21 Nov 2009 17:57 - 21 Nov 2009 18:01
#335122
If you dont have a voltage drop at your coils, and all your connections are clean as they should be, then its reletively pointless.
I have done this mod several times, and it does the job effectively when necessary.
Just keep an extra relay in your backpack, cause they do randomly go bad.
Cheers, good luck.
B)
Origional WG Coil Mod
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 21 Nov 2009 18:01 by TeK9iNe.
  • bill_wilcox100
  • bill_wilcox100's Avatar
Re: coil mod help
21 Nov 2009 20:31 - 21 Nov 2009 20:31
#335151
Here's how I did mine on a '77 KZ-650-B1:
More information here , with Points ignition and Dyna S Electronic ignition.
Best of success. :)
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 21 Nov 2009 20:31 by bill_wilcox100.
