Hooked the Battery Charger up backwards,
  • bountyhunter
  • bountyhunter's Avatar
Re: Hooked the Battery Charger up backwards,
20 Nov 2009 12:44 - 20 Nov 2009 12:45
#334872
If your reg is charging, you should read about 13.5 - 14V at the battery with the engine above 3000 RPM.
Last edit: 20 Nov 2009 12:45 by bountyhunter.
  • Jimbo302
  • Jimbo302's Avatar Topic Author
02 Apr 2010 15:59
#357991
Okay, I finally got around to tracing all the wires and replacing anything that looked suspicious. The starter works great now and everything seems to be fine. Now I need to go get a battery and check out the charging system. As it is, it runs awesome on the charger, but dies when I disconnect it. I'm guessing the regulator will be first on my list. Where is a good place to get a rectifier?
  • MFolks
  • MFolks's Avatar
02 Apr 2010 19:23
#358032
  • Old Man Rock
  • Old Man Rock's Avatar
03 Apr 2010 06:02
#358091
Battery first then check the electrical as depicted in the OEM service manuals....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
