led light ?
  • hmeric7
  • hmeric7's Avatar Topic Author
led light ?
17 Nov 2009 18:35
#334392
ive been looking at putting some new lights on the bike 1977 kz1000 and i was wondering if i had to do anything special if i put led turn signals on it. i see these turn signal led fix relays and resitor set upso nebay
1977 KZ 1000 LTD
  • thane_420
  • thane_420's Avatar
Re: led light ?
17 Nov 2009 19:19
#334407
instead of using resistors you can buy a replacement led flasher bulb
73 kz900 1075,mre clutch,race cut tranny,cams,airshift,34 flatslides, custom rear wheel
76 kz900LTD gsx-r suspension swap, mikuni 29mm smoothbores, stock engine
72 suzuki gt750 2-stroke triple
  • hmeric7
Re: led light ?
17 Nov 2009 20:21
#334427
ah well i dont know really wat the bulb is eather i was gonna buy a hole turn signal assembly for the rear and they have led bulbs built in.
1977 KZ 1000 LTD
  • bountyhunter
  • bountyhunter's Avatar
Re: led light ?
17 Nov 2009 23:05 - 17 Nov 2009 23:06
#334434
You just need an LED flasher assembly. You can get them at auto stores. You take your flasher out and plug in the LED flasher and then the LED turn signals will work.
Last edit: 17 Nov 2009 23:06 by bountyhunter.
  • thane_420
Re: led light ?
18 Nov 2009 13:23
#334482
i have a led tail light w/intergraded turn signals on both my kz's. to make lights flash properly just remove your old flasher "bulb" assembly and put in a led flasher "bulb" assembly
