electronic ignition what will interchange??
- kzkenny
- My wife says it's a sickness...
15 Nov 2009 20:36 #334019
by kzkenny
79 kz650SR, fenders and rear shocks from Z1000 classic
78 650c, clubmans, 750 engine,solo seat etc..
65 el camino
Puch scooter and other crap too numerous to mention...
electronic ignition what will interchange?? was created by kzkenny
Okay, at the risk of looking a little stunned I was told that pretty much all the stock electronic ignition components will interchange on the 550 650 750 1000 etc. I put the electronic components from a newer 650 onto my '79-650 sr replacing the points system. When I ran it up I got backfiring and popping while under revs. I don't have a timing light available, pretty sure I got it all together correctly, is the plug gap different? Had a buddy tell me some time ago when he did his it was just swap out the components and away he went? What am I doing wrong? any ideas? The bike has been parked now for the season but am starting to get the itch to do the winter refurbish and this is one of the things I want done before next riding season.Any help now would be great, would like to get the drivetrain end of it done before starting on the cosmetic.
65 el camino
- otakar
16 Nov 2009 03:18 #334039
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic electronic ignition what will interchange??
Be more specific. What components did you replace? The coils on a points ignition are 4 Ohm the ons on a electronic ignition system they are 2.2 Ohms. This will give you a very short dwell and a very small spark.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- loudhvx
- Thank you received: 1616
16 Nov 2009 09:54 - 16 Nov 2009 09:55 #334084
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic electronic ignition what will interchange??
Just like Otakar said, the old points coils are not really meant to work with the electronic ignition. That may be the issue, or it could just be that your old coils were starting to go out. Did it run fine with points?
Many components will swap between the models you mention, but the actual pickup plates won't interchange between the 1000 and the 550/650/750-4 motors. The 900/1000/1100 uses a larger diameter plate.
The igniters will interchange though.
All of this is only for the earlier electronic ignitions using mechanical advancers. The later ones starting around 83 or 83 depending on model, uses different pickups, and electronic advance. Those parts won't interchange.
I think the electronic ignition coils will interchange between the earlier ones and later ones.
Other issues to check are make sure the advancer is working up to spec using a timing light. Another possibility is that maybe the igniter is getting weak.
If you need a new one, you can make one.
home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html
1981 KZ550 D1 gpz.
Other links.
Last edit: 16 Nov 2009 09:55 by loudhvx.
- rstnick
- Thank you received: 377
16 Nov 2009 10:25 #334090
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic electronic ignition what will interchange??
I had some problems when I did a similar swap as you did, and went back to the points for a while.
I then bought some kz750 coils that are for the electronic set up, and it's worked great the last few years.
The 750 coil's mounts are further apart than the 650's, so some mounting mods are needed. I filed the rear mounting hole further back a little hoping I could do the same to the front (move the hole forward) but could not get nuts onto both mounts.
I ended up using a long zip tie on one end and bolted on the other end.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- OKC_Kent
- Thank you received: 20
16 Nov 2009 10:36 #334092
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic electronic ignition what will interchange??
I've swapped electronic over on my 78 650. Using 550 pickups/plate/advancer cam and 750 igniter. Still have the stock points coils and it's been running smooth for over 30,000 miles...am I looking at having to replace those coils?
Oklahoma City, OK
- kzkenny
16 Nov 2009 10:44 #334095
by kzkenny
65 el camino
Replied by kzkenny on topic electronic ignition what will interchange??
Thanks for the info so far,, I did not replace the coils, they are still the stock ones for the points. They seemed to be working fine when the points were still in. The igniter etc that I used were off a newer 650 or 750 around the 80-81 year range I believe.
65 el camino
- rstnick
16 Nov 2009 10:51 - 16 Nov 2009 10:52 #334096
by rstnick
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Kent if your bike has been fine for 30,000 miles, I think you'd know by now if there were any issues.
My swap just didn't work quite right. Could have been the IC Igniter too as I did change it as well.
I also swapped coils as I thought it may have been part of the problem.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 16 Nov 2009 10:52 by rstnick.
- otakar
16 Nov 2009 11:01 #334097
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
The systems until 1982 take 2.2 Ohm coils. The system will work with 3 ohm coils found on 79s but will have a hard time giving you a good spark on the older 4 Ohm coils. A quick way to find out if that is the problem is to close your spark plug gap to .5mm (.020) see if it runs better. If it smooths out than the coils are your problem.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
16 Nov 2009 11:05 - 16 Nov 2009 11:06 #334099
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
I run the Dyna Gray coils (2.2 Ohm) with mine and have the plug gap open to 1.5mm (.060) It gives better gas millage that way and I have not had any problems with spark blow out with the 11:1 pistons and at 10500revs, on my 1150 motor.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 16 Nov 2009 11:06 by otakar.
