ignition switch, broken wire
- 81kz550b2
Long time since I've been here, but I know where to look when I run into a problem
On my kz550b2 I have a broke wire connection right at the bottom of the ignition switch. There are 4 connections on the bottom of the switch and they're made up from what I believe are steel rivet like tings with a clamp like construction on it. Now the clamp is broken from the rivet, leaving very small steel bulb sticking out of the switch...this is where I have to reconnect the wire to.
Apparently all electricl current actually passes through the ignition switch, so a proper connection is required. I tried soldering the wire to the tiny bulb, but as the bulb is steel the solder wouldn't adhere to it.
Does anyone have any good idea to repair the ignition switch? I was thinking of drilling a 2mm hole into the steel buld, hoping it would be solid steel inside as well...or otherwise try to take the switch apart, but I doubt whether this is possible or not...
Any idea will be considered
1981 kz550b2
1984 kz750E (Turbo)
1989 GPz1000RX (Burnt down on the German Autobahn...)
Enschede
Netherlands
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- 81kz550b2
Or does anyone know by heart which models have the same ignition switches? Mine has 4 connections on the back...would have to take a look at home which color wires attach to it.
1981 kz550b2
1984 kz750E (Turbo)
Enschede
Netherlands
- Thank you received: 2098
For b2 wiring diagram, click here, then scroll down to and open the last item.
Click here first, then scroll down and open last item
Good Luck!
- loudhvx
- Thank you received: 1616
KZ550-A1 (1980)
KZ550-A2 (1981)
KZ550-C1 (LTD) (1980)
KZ550-C2 (LTD) (1981)
KZ550-D1 (GPz) (1981)
The part number for the switch is 27005-5014.
Chances are, the contacts in the switch are worn, so you probably want to forget about fixing the old switch.
The only problem with getting a new switch is that the new key won't work on the seat latch, so you'll have to carry two keys. In the past, I've had some luck at taking a new contact plate and wire plate from a new switch and grafting it onto an old switch assembly in order to keep the old keying the same.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Brown - Blue - White - Red - Yellow
Brown (lights)
Blue (tail 1)
White (battery)
Red (tail 2)
Yellow (ignition)
These 5 wires go to a connector. The wires on the other side of the connector are the same colors except the blue wire from the ignition switch is blue/red on the other side of the connector.
Good Luck!
Edit -- got the on-site 1981 KZ550-A2 wiring diagram downloaded showing the same 5 wire colors and connections as the 1981 KZ550-B2. Believed consistent with info provided by loudlvx.
Good Luck!
- loudhvx
It is a page from the FSM, which I have next to me. However, I'm not sure if that is what he has. He says he has a 2-phase alternator. I assume he means 2-wire (which is 1-phase) alternator, but the diagram shows a 3-phase for the 550b2 and a 1-phase for only the 400j2.
Either way, all of the diagrams for 1981 except the non-us/Canada C2 show the 5-wire ignition switch being the same electrically. (The non-US/Canada C2 diagram shows no way of lighting the tail light in the on-position, so I assume this is an error in the diagram, which would make all 1981 models the same.)
1981 KZ550 D1 gpz.
Other links.
- 81kz550b2
You're right about the alternator, it's a two wire and then obviously 1-phase. I found in the past that this is fairly rare as all other 550's and 750's I've encoutered feature 3-phase alternators.
I wouldn't mind having to use several different keys for different purposes. If you guys are right and this kind of ignition switch is not as rare as I feared it would be...it could be quite easy to find a second hand one somewhere.
For the connections...they seem to be working excellent!
I have a b2 wiring diagram featuring my 1-phase alternator and as far as I've encountered every other aspect of the wiring. I will compare that to different ones I see here. If it's different I will make a scan and upload it here.
Cheers!
1981 kz550b2
1984 kz750E (Turbo)
Enschede
Netherlands
- Kawickrice
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- 81kz550b2
1981 kz550b2
1984 kz750E (Turbo)
Enschede
Netherlands
- Kawickrice
Don't really have to ride still got my 750 Turbo to spare
Now that turbo is a great cure for riding withdrawls
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
