- Thank you received: 1
Turn signal buzzer.
- polkat
30 Oct 2009 23:31 #330599
by polkat
Turn signal buzzer. was created by polkat
As I mentioned in another post here, the turn signal automatic cutoff function on my '82 KZ750 never worked even when new, according to the previous owner. I recently scrapped the switch and put in a conventional SPDP center off type toggle, and chucked the controller. Works fine, but like some here (who may not admit it) I sometimes forget to turn the signals off.
Got the idea to wire in a pizeo buzzer to tell me when the signals are on. Wiring it in shouldn't be too much of a problem, but how to wire it so it isn't buzzing when I'm sitting at a light with the signal on? Anyone done this, and do you have a wiring diagram?
Also, how loud should one be? I've heard that some have used 100db buzzers that can be heard a block away!! I don't want anything near that, but with a full face helmet, and engine and traffic noise, I want to be able to hear it.
Ideas? Thanks!
Ideas? Thanks!
- loudhvx
- Thank you received: 1616
31 Oct 2009 08:26 - 31 Oct 2009 08:41 #330638
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Turn signal buzzer.
If you use the turn signal on the highway to change lanes and forget, you'll probably never hear the buzzer. It would have to be super loud.
Why not just use a timer that shuts off the signal after 1 or 2 minutes?
Matbe something like this?
www.amazon.com/Cancelling-Controller-Eme...ontrol/dp/B0010ED3EK
1981 KZ550 D1 gpz.
Other links.
Last edit: 31 Oct 2009 08:41 by loudhvx.
- polkat
31 Oct 2009 12:04 #330665
by polkat
Replied by polkat on topic Turn signal buzzer.
An interesting idea, but the price is high for what I want. Some pizeo's are quite loud, reaching 100db, which I'm sure can be heard for some distance. I just don't want something too loud!
- bountyhunter
- Thank you received: 337
31 Oct 2009 13:52 - 31 Oct 2009 13:59 #330680
by bountyhunter
Replied by bountyhunter on topic Turn signal buzzer.
polkat wrote:
I just went to radio shack and bought their 12V piezo buzzer. I used double sticky foam tape to mount it on the fork just below the ignition switch assembly. I use a pair of diodes from each turn signal light wire to drive it so it buzzes if either signal flashes. Works great, I can hear it through the helmet at any speed. It's not so loud it would bother you.An interesting idea, but the price is high for what I want. Some pizeo's are quite loud, reaching 100db, which I'm sure can be heard for some distance. I just don't want something too loud!
Last edit: 31 Oct 2009 13:59 by bountyhunter.
- polkat
31 Oct 2009 14:23 - 31 Oct 2009 14:24 #330684
by polkat
I assume that you wired the negative side of the pizeo to ground. If you wire it to the brake switch hot wire (the wire that feeds current to the brake light when the brake is on) it will also act like a ground when the brakes are off. But when you have the brakes on (power to the brake light) the pizeo will loose it's ground and cut off. Since the pizeo is a polar device, the brake light voltage won't hurt it, but if you're worried about that, you can wire another diode toward the brake wire. Just did this and it worked for me!
Last edit: 31 Oct 2009 14:24 by polkat.
- bountyhunter
31 Oct 2009 23:18 #330757
by bountyhunter
I grounded the neg wire and fed the +12 side of the buzzer from diodes coming from either turn signal bulb.
