dyna coils
- marko
dyna coils
21 Mar 2006 06:28
I bought some dyna coils for my z1r and I'm having a problem making them fit to the bike. The anchoring bolts need to be longer and slightly bent almost boomerang shaped. Are their special bolts you buy or do I have to make my own?
Post edited by: marko, at: 2006/03/21 09:28
- wiredgeorge
Re: dyna coils
21 Mar 2006 06:45
Seems to me that the mounts on a Z1R are the same as the mounts on my KZ900 carb testing bikes. The Dyna coils have a fixed bolt position at one end and two holes on the other end where the bolt can be moved. You need to move the bolt to the outside mount position. If you could take a pic, it would be helpful in this case.
