COILS MAKE A POPPING SOUND WHEN IGN SWITCH TURNED
  • arai59
  • arai59's Avatar
Re: COILS MAKE A POPPING SOUND WHEN IGN SWITCH TURNED
28 Oct 2009 20:11
#330237
So what was it ? Or is this gonna turn into more drama ? :laugh: Low voltage ?
  • Old Man Rock
  • Old Man Rock's Avatar
29 Oct 2009 03:29 - 29 Oct 2009 03:33
#330260
Keith, in using the Dyna 3 Ohm coils.... I had to use standoffs to clear the frame (ground) and coil conductors...
As TB mentioned, since you received a jolt (lol, sorry brother couldn't resist) your coil is partially shorting to the frame somehow....
In my pictures, you can review the heat shrink tubing (non conductive) around the standoff tubes. This insures the +12Vdc isn't arching to these grounded frame bolts.
Just a thought...
Another thing, possibly a shorted spark plug? :blink:
Not sure that's possible but change them out just in case.
BTW, my CR's fart when turning the key off as well...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 29 Oct 2009 03:33 by Old Man Rock.
  • keith1
  • keith1's Avatar Topic Author
29 Oct 2009 05:28
#330271
i ve got low voltage all right..at coils and at brain stem......lets put it this way..kzcsi woke me out of my stupor.......
  • keith1
29 Oct 2009 05:31
#330273
Just a thought...
thanks dave....popping noise my own stupidity, but i still have 9.8 to coils....gonna get the stuff to do the mod after work.....
29 Oct 2009 06:49 - 29 Oct 2009 06:50
#330293
Imo, body buzzing voltage from frame likely results from high tension leakage, such as from old hard cracked deteriorated spark plug wires.
Could spray water mist over plug wires with engine running in a dark garage, and watch for fireworks.
Once on a ride, I touched the petcock to hit reserve, and got buzzed through a full fingered leather glove. That was the final incentive needed to replace the old original coils (with rock hard permanently built-in plug wires) with green Dyna 3 ohm coils and new Dyna solid core plug wires (from Z1E), which resolved all ignition issues.
Of course, full battery voltage is needed to the coil primaries. I use tie-wraps around the coil mount spacer as insulation between it and the primary screw head.
Good Luck! :)
[Click on image to enhance view]
Last edit: 29 Oct 2009 06:50 by Patton.
