pick up coils question
  • waterwalker
  • waterwalker's Avatar Topic Author
27 Oct 2009 08:57 - 27 Oct 2009 09:40
#329926
will a set of pick up coils off of a 83 kz 1100 fit or work on a 82 kz 750? i sure hope so. my bike is Canadian also, don't know if that would mater. thanks
Last edit: 27 Oct 2009 09:40 by waterwalker.
  • polkat
  • polkat's Avatar
Re: pick up coils question
27 Oct 2009 15:56
#329971
If an ohmeter shows 400-500 ohms when they are tested, and they fit in the same location (same physical distance from the rotor), I see no reason why they shouldn't work.
  • JR
  • JR's Avatar
27 Oct 2009 18:38
#329990
Good question waterwalker.
I went to kawasaki.com - owner info (lower left) - parts diagrams - motorcycle - 1982 etc etc and looked at igntion parts.
Click on the part# and in the pop up box click on the little yellow ? mark. This gives a list of other models that part may be found on. Sorry to say that for the pulse coil the list only showed the following
Model (8):
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-H1 (LTD) (1980)
KZ750-H2 (LTD) (1981)
KZ750-H3 (LTD) (1982)
  • waterwalker
27 Oct 2009 19:19
#330004
oh well, thats my luck. if anyone knows where i can get this coil set, PLEASE let me know. its frustrating when you have money and want to buy something but you cant find it. i went to the local Kawasaki shop today and they pulled it up but it is "no longer available". anyway, any help would help. and also.....racecar spelled backwards is still racecar.....hope this helps
  • loudhvx
  • loudhvx's Avatar
28 Oct 2009 11:52 - 28 Oct 2009 11:52
#330108
The 750-4, 650, and 550 all share the same ignition housing on the motor. You can get a set of pickups from these 550 models.
KZ550-A2 (1981)
KZ550-A3 (1982)
KZ550-A4 (1983)
KZ550-C1 (LTD) (1980)
KZ550-C2 (LTD) (1981)
KZ550-C3 (LTD) (1982)
KZ550-C4 (LTD) (1983)
KZ550-D1 (GPz) (1981)
KZ550-F1 (Spectre) (1983)
KZ550-H1 (GPz) (1982)
KZ550-H2 (GPz) (1983)
KZ550-M1 (LTD Shaft) (1983)
The part numbers may differ from the 750, but it's only because the wires are different lengths or the connector may be different.
Just make sure the pickups look the same as yours if you find them on ebay. Pickups from other models will work if they look the same, and they physically fit. There is another type of pulser that doesn't look like these. You can't use those pulsers.
Last edit: 28 Oct 2009 11:52 by loudhvx.
  • loudhvx
  • loudhvx's Avatar
28 Oct 2009 11:56
#330109
No eBay APP ID and/or Cert ID defined in Kunena configurationThese may work. You can remove the individual pickups and bolt them onto your timing plate/magnet assembly. The magnets must go back in their original orientation or it won't work.
  • waterwalker
28 Oct 2009 14:06
#330124
i sure hope they work because i just bought them. ill let you know when they get here. anything i need to know when trying to install them? thanks
  • loudhvx
  • loudhvx's Avatar
28 Oct 2009 17:01 - 28 Oct 2009 17:58
#330168
The 1100 timing plate is larger than the 550/650/750 plate so you have to mount the pickup plate on your old timing plate. (It appears the auction was only for the pickup plate, and not the timing plate or magnets.)
This means taking the magnet assembly apart. Here are the details on the magnet orientation.
kzrider.com/index.php?option=com_kunena&...d=4&id=134605#134612
How are you certain your old pickups are bad? Just the ohm readings, or did you try it with a different igniter?
Last edit: 28 Oct 2009 17:58 by loudhvx.
