How much power do HID lights draw?
- hardr0ck68
- Who put the what in the where?
27 Oct 2009 08:54
In my progess of re-working the bike I would really like to install a HID kit. My bike already finds itself short on juice with the wideband o2 sensor. I hope a change in charging systems will fix this but I also want to install the HID kit.
What are the power requirements for this? How does a HID kit compare to the standard 7" sealed beam?
Thanks for any input!
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- kano
- Not Another Bloody Limey!
Re: How much power do HID lights draw?
27 Oct 2009 09:46
my hid kit says:
HID SPECIFICATION
CERTIFICATION: E-MARK AND ISO9001
POWER CONSUMPTION: 35WATTS
VOLTAGE: 85 +/- 17V
LUMINOUS FLUX: 3200
BALLAST CONSTRUCTION: INTERNATIONAL IGNITER
SERVICE LIFE: APPROXIMATLY 3000HOURS
INPUT VOLTAGE: 9V-16V
WORKING CURRENT(Steady state): 3.5 A nom
IGNITION VOLTAGE: 24kV Peak Max, 18kV Peak Min
LAMP FREQUENCY: 450 Hz
- hardr0ck68
27 Oct 2009 14:35 - 27 Oct 2009 14:36
Ok so as I read it the HID kit runs at 35w 3.5amps
Am I reading that correct? It seems that is only slightly more than the bulb I am running now! 50W (low beam) /60W (high beam). To calculate Amps I divide 60w/12v and get 30amp draw while the high beam is on; correct?
1977 kz650 c1
Last edit: 27 Oct 2009 14:36 by hardr0ck68.
- TeK9iNe
- What did you do!?!
27 Oct 2009 15:24
Highbeam: 60Watts, 12Volts = 5.0Amps
Lowbeam : 50Watts, 12Volts = 4.2Amps
The HIDs' accept an input voltage of 9-16Volts.
If the given input Voltage is 12V, and they consume 35Watts of energy, then they will draw 2.92Amps of current doing so.
Hope this helps!
Hope this helps!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- hardr0ck68
28 Oct 2009 08:27
Outch, my crappy math skills make a fool of me again.
Awesome!
So dual HID's it would draw about 70W and 6amps? (at 12 volts)
Thanks for the help.
To me, (I know nothing about the black magic of electrical systems) it seems one HID takes LESS(?) power than the sealed beam, and two are just 10W over my current high beam!
Awesome!
1977 kz650 c1
- TeK9iNe
28 Oct 2009 18:53 - 28 Oct 2009 18:54
Yessir, thats right.
Sounds like a good setup to me
Much brighter, and safer, for only under 1 amp more...
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 28 Oct 2009 18:54 by TeK9iNe.
